del sol cooling fan
del sol cooling fan
My '94 z6 cooling fan never comes on; wtf
I've checked all the wires and relays, but I just can't seem why it won't turn on and its hott as fawk outside..lol
can anyone help me out here
thnx
thnx
only ever saw mine come on once and it was at night. doesn't bother me as my car doesn't overheat, jdm d15b...does yours overheat and it doesn't come on or is it not overheating?
hahah well i don't think you have to worry much unless you're boosting. my temp gauge stays below the 3rd "wave" on the water temp image and as long as it's there/below there i don't worry =p but as someone said it might be the temp sensor..damn hot here in florida, too
Re: del sol cooling fan (lilsol89)
ok test you fan . by connecting the fan wires directly to the battery .. if it does not go on.. replace tha fan.. but if it does go on , the is the fan fuse or the fan relay.. wich both are under the hood fuse container.. check on the haynes manual..
i use to had the same problem..
Modified by sorullo at 5:50 PM 8/22/2008
