Default [FAQ] How-To: Change your Civic Manual Transmission Fluid
Old 07-13-2006, 10:48 AM
  #26
imadigitalgod's Avatar
Default Re: (tommy.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommy. &raquo;</TD></TR><TR><TD CLASS="quote">so when u add the 2 quarts and by the end of it..it should level off on its own? And no more oil will start leaking off right?</TD></TR></TABLE>
it should leak out after u pour all the 2 quarts in since it only holds 1.9 quarts. then it will level off on its own. when it stops leaking out u can put the filler bolt back on
u will notice a lot smoother shifting too.
Old 07-13-2006, 10:56 AM
  #27
Tuesdaynightfever's Avatar
Awesome diy! I know what I'm doing after my oil change next week
Old 07-13-2006, 11:27 AM
  #28
EeeJayEight's Avatar
Default Re: (Tuesdaynightfever)
very good write up.. nice clear pics to.. so for you...
yes.. something to keep my weekend occupied with now!!
Old 07-13-2006, 03:13 PM
  #29
Banned
CardDealer's Avatar
Default Re: [FAQ] How-To: Change your Manual Transmission Fluid At Home (imadigitalgod)
Modified by CardDealer at 9:35 AM 11/16/2006
Old 07-13-2006, 07:09 PM
  #30
Default Re: [FAQ] How-To: Change your Manual Transmission Fluid At Home (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit &raquo;</TD></TR><TR><TD CLASS="quote">When filling, dont you have to make sure you car is level? ie, the front end or side shouldnt be jacked up? </TD></TR></TABLE>
yeah, idk if u saw it but i have that under the picture of my car over the edge. thats y i had the car front end pulled over that dropoff so i wouldnt have to jack it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imadigitalgod &raquo;</TD></TR><TR><TD CLASS="quote">
Make sure the car is on a flat surface. I just pulled my car to the end of my garage where it drops down a little bit. This level surface is needed for proper drainage and filling.
Old 07-14-2006, 06:27 AM
  #31
MurdersV8s's Avatar
Just picked up password magnetic drain plugs. For the tranny, which hole do I put the plug into? The filler or the drain?
Old 07-14-2006, 09:01 AM
  #32
Default Re: [FAQ] How-To: Change your Manual Transmission Fluid At Home (MurdersV8s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MurdersV8s &raquo;</TD></TR><TR><TD CLASS="quote">Just picked up password magnetic drain plugs. For the tranny, which hole do I put the plug into? The filler or the drain?</TD></TR></TABLE>
If you got the magnetic drain plug, you put it in the drain plug hole. Im not sure what you mean by "where do u put it"
Old 07-14-2006, 10:57 AM
  #33
MurdersV8s's Avatar
didn't know if it mattered that my new plug looks like the fill plug and not the original drain plug.
Old 07-14-2006, 12:06 PM
  #34
well, if it fits and doesnt leak then it should be fine. idk y honda made the end like that on the stock one
Old 07-15-2006, 08:52 PM
  #35
does it fit?
Old 07-15-2006, 09:12 PM
  #36
vlc92189's Avatar
question... what is the vss look like on a gsR?
Old 07-15-2006, 09:59 PM
  #37
Default Re: (vlc92189)
ill find a pic. i just find this way easier because i allready have the funnel made so it takes less time to stick it in that fill hole than it is to do the VSS...but thats just me
Old 07-16-2006, 07:49 PM
  #38
DireFire34's Avatar
awesome writeup
Old 07-17-2006, 08:36 AM
  #39
tommy.'s Avatar
Default Re: (imadigitalgod)
thanks
Old 07-18-2006, 05:51 PM
  #40
vlc92189's Avatar
hey bro.. quick question... i know you said it has to be level.. but since people dont have a lift everyday to use.. did you use jack stands? on all 4's? keep 3 tires on or what?
Old 07-18-2006, 06:51 PM
  #41
DelSolMarine's Avatar
i had a clicking lsd... i went a bought an additive cause i was told it will shut it up? does that go in the tranny or do i needa pull the axles and put the additive in the differential? yea im not that mechanically inclined but i get by its the b18c complete swap with lsd
Old 07-18-2006, 08:05 PM
  #42
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlc92189 &raquo;</TD></TR><TR><TD CLASS="quote">hey bro.. quick question... i know you said it has to be level.. but since people dont have a lift everyday to use.. did you use jack stands? on all 4's? keep 3 tires on or what?</TD></TR></TABLE>
the first picture that i had posted is all i did, i just pulled it up to the end of my garage that barely drops off on that edge. i think u can get at it fine by just having it level on any ground without any dropoff. it might b a little difficult but not too hard at all
Old 07-18-2006, 08:11 PM
  #43
Default Re: (DelSolMarine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolMarine &raquo;</TD></TR><TR><TD CLASS="quote">i had a clicking lsd... i went a bought an additive cause i was told it will shut it up? does that go in the tranny or do i needa pull the axles and put the additive in the differential? yea im not that mechanically inclined but i get by its the b18c complete swap with lsd </TD></TR></TABLE>
What type of additive did u get? it should say on the bottle what you need to do but from what i see, u change the transmission fluid out and add it to the new fluid
Old 07-18-2006, 09:02 PM
  #44
vlc92189's Avatar
lol so you kept your wheel on? im confused.
Old 07-18-2006, 09:54 PM
  #45
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlc92189 &raquo;</TD></TR><TR><TD CLASS="quote">lol so you kept your wheel on? im confused.</TD></TR></TABLE>
yes. i just reached under the front of the car to do all of that.
Old 07-19-2006, 09:59 AM
  #46
vlc92189's Avatar
so your saying you did it with the wheels on?
Old 07-19-2006, 11:00 AM
  #47
vlc92189's Avatar
them bolts are like seized on there. i cant get the drain bolt off lol
Old 07-19-2006, 12:26 PM
  #48
breaker bar...
Old 07-19-2006, 09:07 PM
  #49
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolMarine &raquo;</TD></TR><TR><TD CLASS="quote">breaker bar... </TD></TR></TABLE>
Old 07-19-2006, 09:23 PM
  #50
Cold Fyre's Avatar
Excelent writeup. I just hit 90K miles on my '00 EX and it's time to do this.
Quick Reply: Default [FAQ] How-To: Change your Civic Manual Transmission Fluid
