Issue w/ built Y8
Old 12-08-2011, 11:50 AM
EX-T's Avatar
Default Issue w/ built Y8
The issue I'm having is that when the engine is up to temp and I've driven for a little while, when the rpms drop to idle speed, the oil light flickers on and off really fast. I give it a little gas and the light goes out.
There's plenty of oil in it but it only does it when the engine is warm and has been driven for several miles.
Old 12-08-2011, 11:51 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Issue w/ built Y8
Put a gauge on it and check the pressure.
Old 12-08-2011, 11:56 AM
EX-T's Avatar
The pressure's obviously low otherwise the light wouldn't be flickering...
But why only when the oil temp is up and it's been driven... clogged pickup? oil pump? I wish there was a way to block all the channels for the oil to run from the head to the oil pan b/c I'd fill the head up with oil, until it came out the oil cap and them remove then unblock the channels to flush any kind of trash outta there... lol
Old 12-08-2011, 12:21 PM
Retired Moderator
EsotericImage's Avatar
Grumblemarc..
your like Visa..
everywhere you want to be!
You can try a seafoam treatment in the oil and see if that cleans up any crap.. But afterwards, i would replace the oil then with a 2nd oil change.
Old 12-08-2011, 12:23 PM
EX-T's Avatar
you just blew my mind with that one! lol
Old 12-08-2011, 12:29 PM
The Grumpiest
You say it's built. Is the oil pump new? You might want to get a gauge anyway.
Old 12-08-2011, 12:31 PM
furious94ls's Avatar
What kind of oil filter are you running? In the past I've seen cars with low oil pressure at idle. After the filter was changed, all was fine. Sometimes the filters are faulty/weak.
Old 12-08-2011, 12:40 PM
EX-T's Avatar
The oil pump was new Honda when the engine was built about 10,000 miles ago.
I'm gonna try swapping the oil filter out, maybe got some trash in there or something...
Old 12-08-2011, 03:05 PM
apexi_rsx's Avatar
when the light comes on oil pressure is below 3psi. id recommend getting a gauge when my new built motor idles im sitting at 15-10 psi at idle. i shimmed and ported my oil pump. i use a bigger oil filter on mine. a stp 3950
Old 12-08-2011, 03:13 PM
Retired Moderator
well, you want 10psi per 1000 rpms...
you need to put a gauge on and check to see if your getting good pressure thru the range. If not, then you know whats up..
I wouldnt trust the idiot light anyways.
Old 12-08-2011, 09:55 PM
Texas4door's Avatar
Check your connection to see if your oil pressure switch is good or loose.
Old 12-08-2011, 10:10 PM
v8killaz's Avatar
you need a gauge. and **** the stock sensor i leave those thing's unplugged.
if its low enough to trigger the light and the sensor is working properly than i would not run the car until you fix the problem.
slow_low_eddie
08-20-2014 07:04 PM
IBriaIN
02-27-2011 08:28 PM
JStar
04-06-2006 02:29 PM
Mr. Samurai
10
02-28-2005 05:59 PM
apexrift
11-21-2004 11:23 AM
Quick Reply: Issue w/ built Y8
