D16Z6 Turbo Choices
Old 02-12-2005, 12:53 PM
TheJRAD's Avatar
Default D16Z6 Turbo Choices
Just wanted to ask a question about boosting the motor that came in the car.
It was rebuilt about 15K miles ago and is in great condition, as is the transmission and all other mechanical parts. I am nearly finished building a B18B but have ALSO decided to build a high-boost D16Z6. I will do whatever I need to properly fortify the block and increase the displacement to an 81mm bore. All internals will be replaced with after-market parts. I would like to use a turbo-kit if I can, and alter the turbo from the manufacturer, making it basically an install and go kit, plus tuning. As I said, I am looking for high boost (22-30 range) and think I will go with a 75 shot also. Who makes a kit that can meet my requirements? I have only seen the Edelbrock kit that is 100% complete so far, but I do not think the compressor can meet my needs. Any help you guys can give is appreciated.
Modified by TheJRAD at 12:39 PM 2/13/2005
Old 02-12-2005, 01:09 PM
Kyles ej1's Avatar
Default Re: D16Z6 Turbo Choices (TheJRAD)
ive never seen a sohc turbo that boosts that high before, the edelbrok only boosts like 10 psi, good luck with that
Old 02-12-2005, 01:17 PM
TheJRAD's Avatar
Default Re: D16Z6 Turbo Choices (93blkej1)
That is what I was trying to say. If I could take a kit and replace the turbo with a larger one, but still use the parts from the kit, or if there was ANY kits that would boost that high. There is no reason the block could not take it if it was properly prepared. Any suggestions on which kit to get, and which snail to replace the supplied one with?
Old 02-12-2005, 01:30 PM
Lord Helmet's Avatar
Edelbrock sells the smog legal version and the off road version. the off road version is probably the one you want which can boost beyond 20+ PSI. Look for the user Marauder aka Roger, he works for Edelbrock and has the very 1st turbo kit for the D16 in his civic. He's on HT sometimes just email or PM him.
BTW for other high boost kit: XS-Engineering, Rev Hard, DRAG, and Apexi.
Old 02-12-2005, 10:20 PM
TheJRAD's Avatar
Default Re: D16Z6 Turbo Choices (sleeperciv)
Bump
Old 02-12-2005, 10:24 PM
blaster834's Avatar
With you requirements it sounds like peiceing together a kit would be your best choice.
Old 02-12-2005, 10:26 PM
I am a (Trial User) Army
litterbox's Avatar
Default Re: (blaster834)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaster834 &raquo;</TD></TR><TR><TD CLASS="quote">With you requirements it sounds like peiceing together a kit would be your best choice.</TD></TR></TABLE>
I second this.
Old 02-13-2005, 11:40 AM
TheJRAD's Avatar
another bump
Old 02-15-2005, 02:56 PM
torbs's Avatar
check out http://www.straightlinespecialties.com ...they had a d-series hatch with with STOCK internals that made 241whp and ran a 12.5 quarter with no tuning and a blown headgasket...i vouch for anything they have...so yeah, check em out...peace
edit: obvously with a turbo kit...garrett t3/t4 57 trim was the turbo of choice i believe
Old 02-15-2005, 03:38 PM
sohcvtec1995's Avatar
Default Re: (torbs)
look up Boosteded9. He made 300whp on a stock internal d16. ran like 11's in a rex.
Old 02-15-2005, 04:03 PM
Soccerking3000's Avatar
Default Re: (sohcvtec1995)
yuo cant bore out the d16 block to 81mm the largest you can go is 79mm i believe, or in lamens terms 1.8lish. Also psi has nothing to do with anything you could have a small turbo pushing 20 psi while a larger one would be pushing the cfm's with 13 psi. You need to set a hp/torque goal, and then go form there.
Old 02-15-2005, 05:52 PM
T4eg's Avatar
I agree 110%. Doing a custom kit u can the parts u want/need to meet your goal. Also for around the same price or less than a "kit"
Chris
jdmdseries
11-26-2007 07:28 PM
icehayden
06-21-2007 10:16 AM
LudeJdm
03-06-2006 09:04 PM
001020
44
02-10-2004 07:39 AM
Quick Reply: D16Z6 Turbo Choices
