D16z6 torque weight
D16z6 torque weight
What is the torque weight for attaching a D16z6 head to a d16y7 block? i have the pattern but not the weight. Any help would be greatly appreciated. Thank you.
Re: D16z6 torque weight
Are you using the z6 or y7 head bolts/studs?
This is for the z6 OEM head bolts:
This is for OEM d16y head bolts:
If you're using ARP head studs, I believe they get torqued in 2-3 steps, ending with 60 lb-ft (when using the supplied moly lube).
