d16z6 with non vtec distributor?
Re: d16z6 with non vtec distributor? (nextgen)
there isnt a difference between vtec and non vtec dists. just the obd1 vtec head has a different bolt pattern that every other d series head
Re: d16z6 with non vtec distributor? (speedooo)
Non vtec distributor won't bolt up. There is an adapter plate that you can buy but it's about the same price as buying a new z6 distributor.
Re: d16z6 with non vtec distributor? (blu eg22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blu eg22 »</TD></TR><TR><TD CLASS="quote">Non vtec distributor won't bolt up. There is an adapter plate that you can buy but it's about the same price as buying a new z6 distributor.</TD></TR></TABLE>
What? Do you have a link to this adapter plate?
You can hack yours up, and it will fit. As far as I know, the car will run well. The internals, however, are NOT the same. There was a thread on d-series.org months ago describing how a non-vtec distributor will make a vtec engine run poorly, even if it seems to be fine. No further evidence has been introduced (again, as far as I know), so I think that might have been an oddball case.
If you just want to be able to drive the car, a hacked up non-vtec distributor (of the same obd generation) will be perfectly fine. I have never had a problem with mine.
minime-civic
06-10-2007 12:27 AM
FOMULA91
03-12-2005 05:54 AM
-[95cxhatch]-
12-16-2003 06:46 PM
adapter, d16z6, difference, diffrences, distributor, distributors, fit, honda, motor, nonvtec, obd1, plate, series, vtec, vtech, work
