D16Y7 Questions... im new to honda's and need help !!!
i have a question for you all... i relize a bunch of you would say search this but i would rather ask you guys..... i mean i know a lot about cars cause i just sold my 88 toyota supra and learned and worked on it and even went to school and worked in a shop...........but i know nothing about honda engines.
i currently got a 97 2dr hatchback but How much can the stock D16 engine handle??? for performance.. i want to bring it up too 200 hp. is that even a good idea?
Please help!!! thanks
Re: D16Y7 Questions... im new to honda's and need help !!!
It could handle probably between 200-225hp if it's in relatively good shape. The only way you will get that type of power without sacrificing your left nut is to boost it. If you decide to do this, at least swap out the intake manifold for the y8 model design. It is much better than the pos downdraft IM on the y7. Then put together a modest turbo setup and get a good tune.
lol nah more like 6000 HP!!!!!! lol just slapping stickers on the bumper lol
the engine is in great condition, lots of miles, but in great condition
i mean i just had plans to chip it. catback exauhst, intake, headers and a high flow air filter. just for now . but like i said i dont want the engine to blow lol
The Grumpiest
Boost it or swap engines.
How do you know the engine is in great condition? Have you run any compression/leakdown tests? If you had searched you would have found that I/H/E and any other bolt-on for D-series engines is a waste of money. Install them and you will discover that not only did you make nearly no extra horsepower you also wasted a lot of money that could have been spent elsewhere. It ABSOLUTELY will get you NOWHERE near 200hp.
what engine would you suggest i swap too ?
The Grumpiest
It depends on your budget. B-Series, H-series, J-series, K-series. I really would suggest you search but since you won't be prepared for the 20+ conflicting recommendations you are about to receive.
Boost can be had for cheap and if done CORRECTLY, reliable as well. 2 years and going on my boosted D. N/A builds are expensive.
like the B16C3 or the H22....
i want something that will last me a long while and will also give me what im looking for which would be a fast highway car or a back street monster lol but still daily driven...
i want enough room in the engine bay and want it clean.
The Grumpiest
All of your criteria can be had from any of the series engines I mentioned above on boost. The bigger displacement engines have a LOT more torque in them. Now if you want my OPINION I would go H2B. K-series looks good but I like A/C.
The Grumpiest
nope i read it all lol and yes i agree boost it or swap it but im keeping all options in mind....
like earlier someone suggested the H2B ( i think that was you actually lol )
and all the different series.. but im looking for something cheap reliable and is going to give me power when i want it..
The Grumpiest
I repeat; bolt-ons on a D are pointless. Without knowing your definition of cheap it will be hard to recommend anything to you. You gotta pay to play. Cheap and fast and reliable aren't to be used in the same sentence.
lol yeah i got the bolt ons are pointless lol trust me i know lol and by cheap i mean like 2000 to 3500 at most for the engine and conversions lol if that helps any....lol
like they always say, "fast. cheap. reliable. : pick two."
you want 200hp. that's double what this model came with from the factory. (on a side note, why does everyone always think they need 200hp? not a valid performance goal in my opinion.) if you think that number will satisfy your needs get to work on a turbo kit or start shopping for a low mileage B18.
you could also work your way to turbo in stages. start with the Y8 manifold ('96-'98), Y8 exhaust manifold ('99-'00), intake (SRI, CAI, or Y8 stock w/ performance drop in filter. doesn't matter really...), and high quality cat back system. then a Delta 272 cam regrind with larger injectors cam gear a chip and a tune. if you like that but you still want more lose the exhaust manifold, replace it with a turbo and down pipe then reflash the chip and tune again. at this point you may find you need bigger injectors depending.. another point here; you can keep your current transmission, shift linkage and CV axles with the turbo build. anything else will require a different transmission...
...with one exception. F2D/H2D. not a popular route. maybe because it won't help you fit in with the "local scene" like an ITR swap or the like. i dunno. but it is an option and it can get you 200 hp reliably with an accord motor and $700 worth of adapter kit.
your call.
your call.
y7 and y8 Oil pumps are garbage replace that so that would be the first thing i fixed other then that there a good base motor my old y7 mini me (y7 block y8 head) was pretty quick i beat a LS in a EG coupe by a car with stock piping the the dumb stock headers.... but i spun bearings racing another mustang... now i got a JDM d15B not the same my old motor was alot faster but think if u swap the oil pump in it it will be fine... 2 main things id say u should do is Y8 intake manifold and a EX tranni...
People say u cant be fast reliable for cheap but i have....
I know around here ALOT of people are going to K series n B series so they give away there D series parts for free i got a y8 head free tranni for free greddy headers for 20$ y8 intake mani 10$ 2 1/4 exhaust Thermal Traded or stock exhaust
You just gotta look in the right places lol but New is always better
The Grumpiest
your call.
your call.
a small light weight honda that can keep up is what i want for now then slowly build up as i get the money...
thanks for the options man ill keep everything in mind ..
if you dont mind could you friend me so if i have any further qquestions i could just ask you
i trust your information and when i do something to the honda i can keep you posted with performance updates with the stock motor till i can afford the swap lol
ill most likely swap a B18C3 or another B series depending on some other options lol
Oh i dunno about that.. they flow like 25% less... Every y7/y8 i had spung bearings my d15b is fine. n has been fine
N my first y7 had 120k miles second had 115k 3rd had 130k
N yes D series are slow... Thats why im doin LS-V... but it is possible to make a D series fast for cheap.. cause Every one is going B series or K series...
But i know me i started getting into the racing scene n my brother had a mid 13 sec CRX b16 so dont compare ur self to other peoples civics or other peopes builds in there car cause every builds diffrent...
N every one has there own opinion on motors so DO what uw ant dont let people talk you out of what u want to do
The Grumpiest
Yeah but as you stated you also beat your engines down to crap street racing. So for people like you they better upgrade oil pumps since you wanna play Fast and Furious. NORMAL driving is not an issue.
And where do you get 25% less from? 25% less than what? Got a fact sheet to back that up or is that a number you pulled out of the air?
OP. I'm trying to save you a lot of money and time. PLEASE don't go the bolt on route. You really won't see any gains. I went down that path and was not at all happy and was loud and still slow. The only way to get any power out of a D is to turbo it.
