d16y7 failed smog due to spark plug?
#51
Re: d16y7 failed smog due to spark plug?
well i had a crack in my y7 manifold and i passed with no problem's also i have been a certified emissions repair tech in Canada for 8 years and the main cause of failure's on most vehicles is a bad sensor or failed cat not worn plugs wire's or pvc valves the large dent in the side of your o2 sensor means it should be replaced as it's easly damaged . when you get some real experiences let me know.
#52
so i passed the low speed but failed the high one but little , numbers are better than the first time tho and my timing was on 10 not 12 BUT he said im allowed 2 difference , and now he suggested run 91 gas maybe that will help
#54
So what did you end up doing to it before getting tested again ? and 91 will only make it worse it burn's slower then 87 octane that's how it reduce's detonation an ethanol blend would be better as it act's as an oxidizer and fixing your timing would be a good idea.
#55
I changed Both new o2 sensors , replaceD exhaust manifold with a cat , pcv valve , cleaned the iacv , and pumped 89
#56
wow then there is something really wrong with your car . try checking the intake air temp sensor,engine coolant temp,and the throttle position switch . if they check out i would try another ecu. it's not in fuel control
#59
maybe it's time for some seafoam and or ethanol treatment. Is the car idling at its proper 670rpm without any hesitation or other difficulty? Has OP changed his oil? Does OP have any vacuum leaks? If the vacuum hoses are really old, it might be a good idea to replace them.
#60
Are all your vacuum lines on the manifold on and in good shape? You could have a vacuum leak making it run rich. On a 13 or so year old car, it's possible hoses could crack.
As someone said, the grounds could be an issue. The Q101 thermostat housing ground is a sensor ground. If sensors aren't grounded well, they may not read correctly. Just take the cable off and clean both with a little sand paper. Can't hurt anything.
Someone asked about why it's a good idea to get the car hot. The catalytic converter must be up to temperature to operate correctly. It won't do it's job if it's cold. And the engine will run rich while warming up, and when warmed up, should idle at about 14.7:1.
Testing your sensors is a good idea. IAT, ECT, MAP, TPS as it's been mentioned.
#61
O2 sensors are 4 days old , cat super mint , no leaks and idles right under 1k rpm , no leaks I checked my hoses , some people me to put iso heet and take it the same day , I was reading and seems to work but I heard people sayin that using sea foam is the same thing but having sea foam on the car while smog would fail me so I dunno , car had a new oil change , new spark plugs , cap , rotor, wires , and pcv valve any one used iso heet before ?
#62
#63
Did you gap your plugs to spec? You know those are what make the fuel burn, right?
Gapping plugs is easy I did my last set while watching TV in the living room. Get the right tool its like $5 for the wire gauge set. Make sure the gauge set includes your specified gap. There's also a little electrode bending tool on most of the gauges I had to modify it a bit with a dremel to make it work right (in red).
Fear my paint skillz
Or you can just get the round ramp type tool and use it to open up the gap. The ramp type is probably fine for regular copper plugs.
Gap too small = not enough zap to ignite fuel properly.
Gap too big = misfire at high RPM.
#64
so what is the best gap size ? .44 ? i have it at .44 and what gas then 97,89 , 91 ?
#65
#67
so i forgot to update this thread and well wanted to help someone out having the same problem ,so car didn't have a thermostast ... cluster would read normal temp but coolant was not passing by so it was sending the wrong info to ecu it was reading the motor cold . thermostat was installed and passed with flying colors
#68
After all that, and no thermostat?
And the gauge never read too cold?
The ECT sensor is what give the computer the temp info to run properly.
#69
What he meant to say was that the car had no temperature sensor and or a working one. I recently got a civic with the exact same issue as the previous owner was too dumb to figure out the issue.
#70
That timing is wrong for a car with a D16Y7 engine. For the D16Y7, the ignition timing is suppose to be 12 degrees BTDC +/- 2 degrees. The 16 degrees BTDC +/- 3 degrees is for the B18 motors...
#71
I didn't get time to read all the responses to your smog issue. I'll toss in my 2 cents. Check the threads on the head. maybe a cross thread is keeping the plug from fully seating. leaving the symptoms of fresh fuel smell, white hot point plug tips and really poor fuel economy, and inconsistent high c/o levels. I'm surprised the smog tech was able to keep the vehicle anywhere near time without the ses light coming on?
