d16-z9\z6 rebuild specification
hi, i want to know all the specs on torqe and measurmants for my engine.
i have an example of 2 photos of a manual that i found, my question is where i can find the rest of this manual online?
thank you!
thank you!
Re: d16-z9\z6 rebuild specification
ALL TOQUE SPECS ARE IN FT-LB.
A/T Tranny Drain plug......................... 29
M/T Tranny Drain and fill plug..............30-40
Wheel Lug Nuts....................................80
Fuel Filter
Banjo Bolt............................................16
Service Bolt.........................................9
Clamp Bolt...........................................9
Valve cover Bolts...................................7
Spark Plugs..........................................13
Cam Gear Bolt.......................................27
Cam cover crown nuts.............................7
Crank(vibration) damper bolt...................119
Cylinder Head Studs....................1st step..22...2nd..49
Flywheel Bolts M/T................................76
Drive Plate bolts for A/T........................54
Header Bolts to Cylinder Head................22
Header to downpipe bolts.......................33
Intake Manifold Bolts..............................16
Oil Pan bolts...........................................9
Oil pick up tube bolts..............................17
Oil Pump to engine block bolts/nuts...........9
Oil Pump Screen bolts..............................8
Oil pump cover Screws.............................5
Oil filter Housing Bolts..............................9
Rocker arm shaft pedestal bolts................16
Rocker arm shaft end caps bolts................9
Timing belt adjstment bolt.........................31
Rod Bolts............................................. ....23
Main Bearings cap bolts
Separate caps and bridge..........................48
One piece cap assembly............................33
Water pump pulley bolts.............................9
Thersmostat housing bolts..........................9
Water pump attaching bolts.........................9
Fuel injection service bolts
88-90................................................ ......9
91up.............................................. ..........11
Throttle Body nuts.....................................16
Fuel Rail nut..............................................9
Manual Transmission
Countershaft locknuts................................65
End cover bolts.........................................9
Selector arm holder bolts...........................9
Tranny case to Flywhee housing..................20
Tranny to engine bolts
4 speed............................................. ........33
5 speed............................................. ........50
Clutch pressure plate bolts...........................19
Release fork bolts........................................22
Driveaxle/hub nuts.......................................134
Brake hose to caliper banjo bolts (front/Rear)...25
Master Cylinder Mounting nuts.......................11
Brake Booster mounting nuts.........................9
i found this on HT somewhere a while back.. i saved it.. hope it helps
Fuel Filter
Manual Transmission
thanks! that information was very helpful, what about mearusment in the engine that i have to use with the feeler? (Thickness Gauge).
thanks
thanks
