d15b engine with a stock 95 civic lx clutch
Old May 10, 2007 | 10:13 PM
denniscoles's Avatar
Default d15b engine with a stock 95 civic lx clutch
are they compatible?
Old May 11, 2007 | 02:12 AM
lv6l's Avatar
if they are both sohc manual cars they will fit
easier to understand is : if the clutch came off a sohc car it will fit.
Old May 11, 2007 | 08:07 AM
Default Re: (lv6l)
frick i meant transmissions. from the stock 95 with a d15b swaped in will the trannie work with it.
Old May 11, 2007 | 09:40 AM
daluv's Avatar
Default Re: (denniscoles)
As long as the splines on the input shaft are the same (which Im pretty positive they are) it will work.
Old May 11, 2007 | 09:53 AM
lv6l's Avatar
its too much work to line up the splines or look at it to tell if the splines are the same or not. here's an easier way. if you are talking about transmission in the first place here is your answer. all tranny that came stock with U.S. 92-95 Civic ANY models will fit your d15b.
with the d15b you are aiming to get parts mainly from the 92-95 civic Si(d16z6). since this is the motor that is most similar to the d15b. but again, any model civic year 92-95 parts are interchangeable. well most, not all.
DAlexsanderC
Transmission & Drivetrain
Jul 21, 2010 04:25 PM
MeCrab
Mar 24, 2008 08:45 PM
dem0nk1d
Nov 6, 2006 12:13 PM
dem0nk1d
Oct 7, 2006 11:20 AM
allmotor.net
May 1, 2002 03:54 PM
