D15b in 98 civic empty oil? Compression fine
Hey ... Just did a swap put in a d15b into a 98 civic still obd2 .... Oils empty 2 times in 2 weeks I've filled it... Thought maybe it was the rings but pretty sure compression read 175 psi on all 4 cylinders? Any ideas? Lots of blue-ish smoke out the back end when you hit the pedal... Check engine light came on... Not sure what to check next?! Valve seals? Or any ideas would be awesome! Thanks
Re: D15b in 98 civic empty oil? Compression fine
thank you! I dont know if there is a way to officially out-rule the rings? And should i replace the guides well im at it aswell?
jango_night
16
09-15-2011 04:44 PM
Jet Black
12
06-08-2004 08:05 PM
