d15b 3 stage vtec ecu ? ( e motor ) wich ecu ?
Going to swap in a d15b 3 stage vtec motor into a obd2b ( 99-00) civic EX .
Currently has a d16y8 with an automatic transmission.
Going to keep the automatic transmission that is in the car and just swap out the D16y8 that is in it now and swap in a d15b obd2 motor ( hopefully i can find a obd2b one over a obd2a).
Now wich ecu would work best with my automatic transmission.
The 5 speed one or the CVT automatic one.
I was thinking as I dont have a CVT transmission Im better to sticking with the 5 speed correct ?
Also
Anyone know the ecu code for the 99-00 models ( obd2b )
( i have gotten a few links and they say p2j is for obd2a and p7j for obd2b ? )
any help or links would be great.
Thanks
Also
Thanks
Re: d15b 3 stage vtec ecu ? ( e motor ) wich ecu ?
well this is what i found so far
37820-P2J-003 obd2a manual
37820-P2J-J11 obdb2 manual
37820-P2J-J61 cvt obd2a
37820-P2J-J62 cvt obd2a
37820-P2J-J63 ? ( guessing obd2b cvt)
37820-P2J-J71 ? (guessing obd2b cvt )
Seagull Management
Neither ECU will work with your transmission. You'll either have to swap to a 5 speed and run the manual P2J or keep the automatic and run a Y8 ECU and accept the fact that it will never really work quite like it should.
Why wouldnt it work well ? ( just want a reasoning to get a better understanding and give it another aproach )I was thinking it would probably do better with the cvt ecu. At least it will read some information from the car. And the automatic transmission ecu will do the rest.
There was a link i bumped into, a 97 civic hx with the usdm version of lean burn. Was on the 3rd cvt transmission so did a automatic swap from a donor civic .
Said it worked well, but always had a check engine light but still got 35-40mpgs. ( so im assuming the lean burn is still working )
Seagull Management
What ECU was used? I just can't see the transmission shifting properly with a P2N CVT ECU.
3stage96
24
06-09-2015 09:49 AM
