d series trans questions
I have a 94 cx model hatchback with a 97 vtec d16y8 engine swap. My tranny is the stock cx model 5 speed. Will my car be faster and more snappy with a ex, si trans in it? I top out at 80mph in 2nd gear. It kills my low end.
Modified by eg94hbhonda at 2:56 PM 10/5/2007
Re: d series trans questions (994door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994door »</TD></TR><TR><TD CLASS="quote">technically its vtec with no -</TD></TR></TABLE>
fixed it, i looked at it after and saw that...the h22 valve cover reminded me
i was just too lazy to change it
=P got it tho
=P got it tho
Re: d series trans questions (eg94hbhonda)
ah see hes asking about a d series tranny on said engine topping out at 80 in second... that would mean- 97 d series vtec- meaning- d16y8. yes an ex/si tranny would help your acceleration considerably. make sure its not an A000 stamped case though since that would be what you already have. and just in case you are going to ask- s20, s40 is the model year with s20 being 92-95 s40 being 96-00. either will work in your car. plug and play.
Re: d series trans questions (fabe85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabe85 »</TD></TR><TR><TD CLASS="quote">man get a 93-95 ex d-series tranny. trust me. all others is bs for a d, even for boost its the best!!!</TD></TR></TABLE> its 92-95 and actually the si has a little shorter gearing but not much. 92-95 also has aluminum shift forks whereas 96-00 has steel. aluminum breaks, steel bends. some swear by the steel some by the aluminum, but if the steel bends, they tear the whole trans up while the aluminum breaking might do considerably less damage.
