D series rubber or b series rubber
lol just need a simple answer
swapping a gsr into a 97 hatch. tranny mounts, do i need to buy b series rubber or will the si brackets work with my stock d series rubber?
and if its not too much trouble..... do i HAVE TO even use the drivers side tranny mount? it looks to me like the passenger side mount would be fine but help if you can
come on guys i need to know so that i dont waste my money tomorrow if i dont have to. can i use the stock d series rubber for the tranny mounts or do i HAVE TO buy the rubber from an si?
Im not entirley sure on this, they may both be the same for D and B. I recently called up Inlinefour to find out about replacemnt moutns for a D series motor, and they told me to get their B series, cause they were the same thing. Not entirely sure on all that tho, maybe someone else can clarify.
Re: (97Ej6mike)
you need b- series motor mounts, if thats what you are asking.
also<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhatch978 »</TD></TR><TR><TD CLASS="quote">do i HAVE TO even use the drivers side tranny mount? it looks to me like the passenger side mount would be fine but help if you can</TD></TR></TABLE>
I would reccomend using all 5 motor+tranny mounts. not safe without them. are u missing a mount or something?
im not missing a stock mount i just dont have the b series tranny mount, i can get the passenger side one at my job for less than $70 with the rubber but the drivers side one is twice as much. ive heard of people not using either tranny mount so i am leaning toward just using the passenger side mount and bracket.
Re: (ekhatch978)
well thanks for the lack of input. im going to help people out here who are doing a b18c1 swap into an ek. You only have to replace the tranny mopunt brackets not the actual rubber mounts. I went and wasted my money on the rubber, only like $40 i think. you cannot use the rubber from a b16 tranny mount, it does not work with other ek's unless you want to cut pieces out of your frame.
ShortbusEK
04-23-2002 03:21 PM
