d series oil pan?
Re: d series oil pan? (hatch808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch808 »</TD></TR><TR><TD CLASS="quote">are all d series oil pans the same?</TD></TR></TABLE>
No, there not all the same. Some of them are shaped differently, which by cause problems depending on the oil pick up. And the 00 d series pan has a different bolt pattern then the older d series pans.
Re: d series oil pan? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">
No, there not all the same. Some of them are shaped differently, which by cause problems depending on the oil pick up. And the 00 d series pan has a different bolt pattern then the older d series pans.</TD></TR></TABLE>
This is true. I had to tap my stock oil pan instead of the already tapped y7 oil pan that came with my turbo kit. It was off by two bolts about a quarter inch for each one.
Re: d series oil pan? (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ »</TD></TR><TR><TD CLASS="quote">So, can I get away using a Z6 oil pan on my Y8 motor?
-PHiZ</TD></TR></TABLE>
yea
yea
