Cutting Stock springs
Now before you ask...please refer this following link. It is a link to a tread on a local car enthusiast board. Please read and give me your opinions. Please read the entire thread..its only 2 pages long.
http://forums.ok-speed.com/showthread.php4?t=2035
Khoi
Khoi
Re: Cutting Stock springs (Sohc Driver)
I didn't really want to read another board for 2 pages but I think everyone will agree, there is no reason you need to cut springs. There is so many decent lowering springs out there for around $100 and you'll be doing it the right way.
Re: Cutting Stock springs (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">I didn't really want to read another board for 2 pages but I think everyone will agree, there is no reason you need to cut springs. There is so many decent lowering springs out there for around $100 and you'll be doing it the right way.</TD></TR></TABLE>
Please read it....i agree with you also..but i have no good concrete proof to tell this guy otherwise...
K, here's your concrete proof. When you cut the springs you will be screwing up the molecular structure that the original engineers desinged them for. Hence, you will have screwed up the springs and they are not what was intended to be used on your car. It's unsafe and idiotic. Ask him how his leg would work if someone changed their molecular structure by say cutting out his knee caps.
Lowering springs are progressive. They take in account the amount they lower your car and make up for it with a stiffer spring rate as they compress. Cutting your springs will lower your car but still give you the same spring rate as you would have stock so your car will ride like a boat till you hit the bump stops. Not the right way to lower a car. Cutting a inch or less more than likely won't hurt anything but if your going to go through the trouble of removing the spring you might as well do the right thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver »</TD></TR><TR><TD CLASS="quote">
Please read it....i agree with you also..but i have no good concrete proof to tell this guy otherwise...</TD></TR></TABLE>
i see you from oklahoma.. and you got aa too haha.. tight tight.. ive seen your aa page before and was like.. this guy got some style..
Re: (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">Ok, will do
Thanks Matt!! Much appreciated! Everyone else..go check out the link..and give your input. My name is also Sohc driver on this board....
Khoi
Khoi
Re: Cutting Stock springs (eli_vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eli_vang »</TD></TR><TR><TD CLASS="quote">
i see you from oklahoma.. and you got aa too haha.. tight tight.. ive seen your aa page before and was like.. this guy got some style.. </TD></TR></TABLE>
LOL..thanks man....where are you from? Texas or Cali i am assuming..thats where most vietnamese are from anyways...
Khoi
Khoi
Re: Cutting Stock springs (USDMDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 »</TD></TR><TR><TD CLASS="quote">Sorry not going to waist my time on the 2 pages..but
Please do not be ghetto and cut your springs.
Save yourself some money and get a nice cheap setup. </TD></TR></TABLE>
Gee.....uh.....thanks......but...uh...check my sig...and go read the link before you make asumptions
I cut my stock springs about 2 years ago or so. Never really had a problem except resently i had to get a wheel alignment due to a bad toe nail. But if you get a camber kit youll have no problems. Any questions you got about cutting stock springs just PM me.
Edit: I just read some of the other thread that you linked. Its not true about the shitty ride. You still have stock ride but dropped. If you do cut 2 more springs get a alignment right after, it will save your tires.
Re: Cutting Stock springs (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">I cut my stock springs about 2 years ago or so. Never really had a problem except resently i had to get a wheel alignment due to a bad toe nail. But if you get a camber kit youll have no problems. Any questions you got about cutting stock springs just PM me. </TD></TR></TABLE>bad toe nail?
wow...you live in washington?? and have a girlfriend in Tulsa??? holy crap..how did that start...and how is that working out...
Khoi
Khoi
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">Lowering springs are progressive. </TD></TR></TABLE>
not all of them. most springs are linear.
why dont you save some money and buy some ebay springs? its better than ******* up your
springs. my friend once did this to his camry. we had to torch and bend the springs so that
it'll seat properly on the strut mount.
btw, this is in the tech forum too.
Modified by Mr. Choi at 10:53 PM 12/21/2003
Re: Cutting Stock springs (Mr. Choi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Choi »</TD></TR><TR><TD CLASS="quote">
Modified by Mr. Choi at 10:53 PM 12/21/2003</TD></TR></TABLE>
Sorry Mr. Choi, i didn't think it would bother or annoy anybody because i posted this topic in the tech and the civic forum....does this annoy anybody else for christ sake....
Khoi
Khoi
Re: Cutting Stock springs (mycivicstoo(s)low)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycivicstoo(s)low »</TD></TR><TR><TD CLASS="quote">bad toe nail?</TD></TR></TABLE>
Apparently its when your inner side of your tire wears out faster then all others, like this pic. I was told its called a bad toe nail, i could be misinformed on the name.
Re: (ju_ju)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ju_ju »</TD></TR><TR><TD CLASS="quote">K, here's your concrete proof. When you cut the springs you will be screwing up the molecular structure that the original engineers desinged them for. Hence, you will have screwed up the springs and they are not what was intended to be used on your car. It's unsafe and idiotic. Ask him how his leg would work if someone changed their molecular structure by say cutting out his knee caps.</TD></TR></TABLE>.... thats so true.. cutting your springs is retarded.. and is totally unsafe.. my neighbor is a cop and when i was putting my suspenison in on my driveway he walked over and said that it was good that i bought all the proper parts because the cops are starting to give grpund clearance tickets and **** .. he said that alot of kids drop there cars the WRONG way (cutting spings) and he said thats if he pulls over a car to check ground clearance and it is below a certain inch they check make the people turn thewheel all th way to onesdie and they check their springs and if they dont look after market they get a summons... i have never gotten checked but this is what he was telling me that improper susension alterations are causing major problems.. just relaying info i was told by a COP
New User
Not aligned or improper camber. Toe is a functional part/measurement of your suspension.
New User
Here is some concrete proof:
Honda: Engineered design specifically made to handle the weight distribution, movement, and comfort for the specific model of car or chassis.
Friend: Non educated in the engineering field. He does understand the above concepts.
Enough said.
You do realize when you drop your car you're losing performance. Let me explain.
You drop your car. Engineering and design goes out the window. Your camber is designed to evenly align your tire which gives traction to the road. Once dropped, you don't have %100 of you tire on the ground. Therefore, no traction, no grip, less performance. Very dangerious...
So do us all a favor, teach someone, or punch them in the face with ignorance.
Enough said.
Re: Cutting Stock springs (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 »</TD></TR><TR><TD CLASS="quote">
Enough said.
So do us all a favor, teach someone, or punch them in the face with ignorance. </TD></TR></TABLE>
Very well said.
Enough said.
Very well said.
k20-rice-cookin-gmachine
Honda Civic (2006 - 2015)
10-03-2007 12:05 PM
bo0sted
05-28-2004 01:45 PM
