Curing the 3rd gear grind
Old 02-03-2011, 05:41 AM
Creepsjr's Avatar
Default Curing the 3rd gear grind
Hey all,
Well it seems my 3rd gear is starting to go for the worse. I have a '99 Civic SiR (canadian), and it seems that if I am switching gears from 2nd to 3rd at high rpms (5500+), the shifter does not want to engage, and as you guessed it, makes a lovely grinding sound.
The car is equipped with the stock B16a2 engine and I believe S21 transmission (I believe). I couldn't find a definitive answer. What should I look into replacing in order to cure the 3rd gear grind, other than the synchronizer?
As much detail as possible here would be greatly appreciated! (part numbers, part names, whatever you can tell me.)
Thanks!!
Old 02-03-2011, 05:56 AM
Seagull Management
94EG8's Avatar
Default Re: Curing the 3rd gear grind
You'll want to pull it apart first and inspect parts to see just exactly what you need, but chances are you'll at least need the synchro, sleeve/slider and possibly the gear and hub.
Old 02-05-2011, 05:48 AM
ekblackcoupe's Avatar
my buddy put a GM product called syncromesh (or something like that) in his tranny. drained all the old fluid out, put said new oil in, and voila! no moar third gear grind. give it a shot i guess
Old 02-05-2011, 05:53 AM
ss_zoidberg's Avatar
^^ Gm synchromesh-friction modified it helps with smoother shifts. Worked well in taking away the grind in my old gsr tranny.
Rickvanuden
Transmission & Drivetrain
06-08-2017 09:00 AM
b16a4
03-07-2007 03:55 PM
bustedasscivic
11-16-2003 09:59 AM
Quick Reply: Curing the 3rd gear grind
