cuCEL code 67 . . . Bad catalyst?
Old Mar 3, 2004 | 02:53 PM
EG2 SiR's Avatar
Default cuCEL code 67 . . . Bad catalyst?
I checked this CEL code for my bro in law.. and I'm just curious as to what sensor would give this code... I initially thought it would be the secondary o2, but that CEL code is 65.... any ideas as to what sensor would send this signal??
TIA
Old Mar 3, 2004 | 03:08 PM
EG2 SiR's Avatar
Default Re: cuCEL code 67 . . . Bad catalyst? (EG2 SiR)
No one??? BUMP
Old Mar 3, 2004 | 03:19 PM
EG2 SiR's Avatar
COME ON!!!! ANYONE????
Old Mar 3, 2004 | 04:47 PM
EG2 SiR's Avatar
No Tech guys on right now?
Old Mar 3, 2004 | 07:09 PM
EG2 SiR's Avatar
so you mean to tell me that NO ONE on honda tech has had this happen?
Old Mar 3, 2004 | 07:20 PM
h2392si's Avatar
i would lik to know ths as well as i hae the same code. I think its my cat and will probably have to get a new one but im going to get a test pipe and an exhaust for it later since the cat is way too expensive, pe ace.
Old Mar 4, 2004 | 04:48 AM
EE_Chris's Avatar
The secondary O2 sensor is whats responsible for letting the ECU know that the catalytic converter is functioning correctly. Since the converter uses O2 to do its job, the signal coming from the 2nd O2 usually shows a rich condition. When the 2nd O2 begins tracking the the primary O2 signal, the ECU is left to believe the converter isn't working correctly.
Did he install a test pipe or high flow cat?
Old Mar 4, 2004 | 10:35 AM
EG2 SiR's Avatar
Default Re: cuCEL code 67 . . . Bad catalyst? (EE_Chris)
No, but I think he has bad rings.. and that probably contaminated his cat. Thanks.. I assumed it was the secondary o2.. but wanted to be sure..
thanks dude.
EF8IGHT
Jan 10, 2006 02:52 PM
impr323
Jun 21, 2005 05:29 PM
2000fbp
Mar 18, 2004 09:12 PM
Qwikrex
Jul 29, 2002 08:23 PM
S13 slide
Jun 2, 2002 03:30 PM
