CTR Intake Cam Vs. ITR Intake Cam
Re: CTR Intake Cam Vs. ITR Intake Cam (SA_SoLcHyLD)
The CTR and newer ITR intake cam is so similar, that you probably wouldn't see a difference on a dyno, and you definately wouldn't feel a difference. The specs are almost identical.
Re: CTR Intake Cam Vs. ITR Intake Cam (rodrez.)
Kew, Kew, but juss wondering...i have a source thats gonna sell meeh his brand New ITR Cams, dual valve springs, and retainers from a USDM Type R i believe...and i was wondering, but u said taht the newer ITR Cams are simalar to the CTR's...is that form a USDM R or JDM R
TSPeed Factory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez. »</TD></TR><TR><TD CLASS="quote">The CTR and newer ITR intake cam is so similar, that you probably wouldn't see a difference on a dyno, and you definately wouldn't feel a difference. The specs are almost identical. </TD></TR></TABLE>
i believe it is the 00-01 ITR cams that are nearly identical to CTR cams.
be professional
Re: CTR Intake Cam Vs. ITR Intake Cam (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">
i believe it is the 00-01 ITR cams that are nearly identical to CTR cams. </TD></TR></TABLE>
As far as listed specifications go, '00-01 ITR cams are identical to CTR cams. There is no difference.
The '97-98 ITR intake cam has a whopping 3 degress less duration @ 1mm. Whoopdeedoo.
Re: CTR Intake Cam Vs. ITR Intake Cam (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
That's what I used to think also.
be professional
That's what I used to think also. </TD></TR></TABLE>
Used to? Has anyone actually found a significant difference when measuring? All of the spec listings I have seen indicate they are the same, but I have never measured them personally to confirm.
Used to? Has anyone actually found a significant difference when measuring? All of the spec listings I have seen indicate they are the same, but I have never measured them personally to confirm.</TD></TR></TABLE>
Yeah, my motor/tranny guy measured them side by side, and the CTR had a tiny bit more duration. But like I said, it not enough to make any difference, they're almost identical. Either cam will do the same job.
be professional
Yeah, my motor/tranny guy measured them side by side, and the CTR had a tiny bit more duration. But like I said, it not enough to make any difference, they're almost identical. Either cam will do the same job. </TD></TR></TABLE>
Interesting. Thanks for the clarification
Interesting. Thanks for the clarification </TD></TR></TABLE>
No problem..........I lost 10bux on that bet
Hit the nail on the head.
I remember reading an MD post on team-integra and he said that teh extra 3 degrees of duration won't make any difference on an engine with a r/s ratio like the b18c's.
One would ask why did honda bother with this upgraded cam? Seeing how they don't even claim anymore power with it on the newer itr's, i would guess that it was designed for the ctr -and they perhaps just used it on the itr to avoid making two cams. Just a thought.
d
d
Re: CTR Intake Cam Vs. ITR Intake Cam (daver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daver »</TD></TR><TR><TD CLASS="quote">One would ask why did honda bother with this upgraded cam? Seeing how they don't even claim anymore power with it on the newer itr's, i would guess that it was designed for the ctr -and they perhaps just used it on the itr to avoid making two cams. Just a thought.
d</TD></TR></TABLE>
dude, read, they arent the same cam
d</TD></TR></TABLE>
Re: CTR Intake Cam Vs. ITR Intake Cam (BoostedJeff)
i've read, i've searched, i've laboured for hours on this, and the honda-tech consensus was that they are identical. Have we changed the ruling?
d
d
Intake exhaust
Lift Duration lift Duration
Civic Type R 11.5mm 243 @ 1mm 10.5 mm 235 @ 1mm
Integra Type R 11.5 mm 240 @ 1mm 10.5 mm 235 @ 1mm
Hope this can help you out.
Intake exhaust
Re: CTR Intake Cam Vs. ITR Intake Cam (boricuatuning)
what is the usdm exhaust cam lift and duration for a b16a2
would a ctr or itr intake and b16a2 exhaust cam combo be good?
would the a2 exhaust cam keep up???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boricuatuning »</TD></TR><TR><TD CLASS="quote">
Intake exhaust
the word is, that the 2k+ itr intake cams have the extra 3 degrees of duration. You havn't specified the year of cams in your post, or your reliable source.
d
Intake exhaust
d
