CTR - clutch noise - help
i started this thread on another site but didn't really get anywhere except causing an argument between some people. in my ctr swap there is a new exedy stage-1 clutch/flywheel...about 2 months old. the clutch has been making strange scraping noises after it gets warmed up.
this has gotten way worse over the last 24 hours. the scraping noise is much louder today than yesterday...it makes noise even out of gear, just going over bumps in the road. it is especially noticable from a start when shifted into gear. it almost sounds like that scraping you hear when your brake pads wear down to their warning tabs. only i know it's not the brakes, i just replaced pads two weeks ago.
no, the bolts are all torqued...could it be one of the cylinders? master/slave? do i need some kind of adjustment? it's starting to sound bad...definately not normal
I would check the easiest **** first and move on up. When mine did something like that my clutch had **** some springs and it was making it where it wouldn't disengauge. Post up what you find out.
just pulled it into garage, i'll be working on it most of the day, i'll post what i find tonight. so far, clutch fluid was full, bled the lines for air...everything's looking good so far
