CTR 5 lug vs. ITR 5 lug
Re: CTR 5 lug vs. ITR 5 lug (MikeNice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeNice »</TD></TR><TR><TD CLASS="quote">ITR works and probably easier to find.</TD></TR></TABLE>
go with itr
go with itr
Re: CTR 5 lug vs. ITR 5 lug (wizzards581)
they are identical
EXCEPT the 1998+ jdm itr's have larger axle nuts and the axle's threaded end is different.
HTH
HTH
Re: CTR 5 lug vs. ITR 5 lug (owen_the_soyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy »</TD></TR><TR><TD CLASS="quote">they are identical
HTH </TD></TR></TABLE>
Munkyw3rkz.webs.com
1 Post
Re: CTR 5 lug vs. ITR 5 lug (hondahans)
all the 5 lugs are the same except for the JDM ITR which has a 37 spline axel vs. the 32spline. correct me if im wrong. i personally have s CTR set up.
Re: CTR 5 lug vs. ITR 5 lug (SnoFlake EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnoFlake EG »</TD></TR><TR><TD CLASS="quote">all the 5 lugs are the same except for the JDM ITR which has a 37 spline axel vs. the 32spline.</TD></TR></TABLE> only 1998 and newer jdm itr had a bigger axle nut/spline end.
CTR and ITR are all the same, except obviously with a ITR setup you will get parts that will bolt right into your EG, so dont get CTR unless you own an EK just to make your life easier. you can use ITR upper and lower LCA's which you would have to swap over from your EG to get the CTR 5lug to work.
the only diff is 98+ JDM ITR is 36mm axle nuts, which are basically 97+ Prelude Axles which you can get anywhere, no need for special jdm axles.
jdmjohn02
01-12-2004 12:03 AM
