Cruise Control Button back light flaky?
Ok, The green light that tells you the button is engaged is working fine and so does the cruise. But, the back light for the WORD "cruise" on the button is lit some times and some times not. It does NOT change if you tap it push it on and off or adjust the dimmer control next to it. It just comes on a goes out for a few days at a time?
Re: Cruise Control Button back light flaky? (shamoo)
speaking of those lights, anyone know what size they are, a few of mine are out.
i also believe your bulb is loose, as far as popping htose things out, i found it easier to take that trim around the cluster off to get to them easier
Re: Cruise Control Button back light flaky? (93egsedan)
"trim around the cluster off to get to them easier" Are you speaking of the trim around ALL the gauges or just the rounded rectangular one around the button itself? You have a pdf. by chance?
Dustin Earley
Honda CR-V & Element
06-13-2017 03:32 PM
go2sleep
07-06-2006 10:06 AM
