Crazy Tachometer
Crazy Tachometer
Hey everyone. I have a 92 honda civic lx 4dr sedan. My tachometer goes nuts when I drive the car. This randomly occurs when ever it feels like it. I have had this problem before. Last year the same thing happened. Eventually my car started to go to zero rpm's and wanted to shut off. My distributor had died. I replaced it, however, months later I still have the same problem. Anyone have an idea what this could be?
Samurai Hakai
Modified by samuraihakai at 11:38 AM 2/17/2005
Samurai Hakai
Re: Crazy Tachometer (samuraihakai)
you have a bad vss. Vhecicle speed sensor. brand new they run about 90 bucks you can find them used around 30-40. search the classifieds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by samuraihakai »</TD></TR><TR><TD CLASS="quote"> My tachometer goes nuts when I drive the car.
Last year the same thing happened. Eventually my car started to go to zero rpm's and wanted to shut off. My distributor had died. </TD></TR></TABLE>
So is this an engine or a tach problem? Does the RPMs of the motor fluctuate, or is it just the tach?
Re: Crazy Tachometer (EX_AutoXer)
before you buy anything make sure its not a loose ground. Check your grounds and make sure they are clean and tight (frame rail, valve cover, thermostat). If everything looks good then what i would do is swap out your gauge cluster with a friends to see if thats your problem, before blowing money.
CRISIS
24
07-21-2006 10:34 AM
del_parker
05-07-2003 05:07 AM
