crazy spark
crazy spark
ok ive never came across this before. new wires new plugs and another dizzy. you can pull the plugs wires off the spark plugs and it sparks all the way to the dizzy off the motor, everyone of the wires. like i said ive replaced everything still does it. i have all the factory grounds. d15b7 motor 94 civic. also as soon as you give the car gas it want to go dead if you pump the gas pedal it does fine. anybody know the problem or has had this problem that can help. thanks bucky
Re: crazy spark
Are you removing the plug wires while cranking the engine or with the engine running? This can ruin the coil. Why are you doing this? Do sparks still jump from the wires with them connected to the plugs?
Re: crazy spark
the car was missin bad. i pulled the wires why the car was running. i had 2 burnt valves, replaced the head and it idles fine but as some as you push the gas it bogs down and trys to go dead. i pulled the wires back up just to see if it was sparkin like that still and it is. ive never seen one spark like that unless the wires are bad but ive done put 4 different sets of new wires on it.
Re: crazy spark
i bought a different name brand spark plug wires. i tried 4 different sets of them one wires and took the last set back and payed the extra money for a better set problem fix car runs great. weird
Re: crazy spark
i cant remember the name, but they are the 39.99 ones at advance auto parts. yea thats the only kind of plugs i run. they didnt have ngk wires in stock and i was needin them tht day.
utn
06-26-2007 01:36 PM
BigMikeyStyle247
04-23-2007 02:56 PM
gimme_h22
10-10-2004 02:58 PM
