Coolant leaking by oil pan??????
Does anyone know whats going on... I recently replace my head gasket on my b16a2. But before I replace the gasket, I notice that there was a leak of coolant running down the oil pan. I thought to myself that maybe the water pump is bad so I replace the unit with an new water pump. I'm done with replacing the water pump, the head gasket and replace the thermostat. I went to start up the car and watch if it was still leaking. I can only see the top part of the water pump, the timing cover is blocking the rest. I dont know why its leaking again when i replaced it, or even if it is the water pump. i looked all round to see what could cause the leak, but the only thing i can think of is the water pump.
Any help will be helpful, thanks.
Re: Coolant leaking by oil pan??????
If it's near the timing cover it could be the pump seal against the block, the o-ring of the coolant pipe coming from the back of the pump, headgasket, crack, manifold gasket or one of the bypass hoses coming from the IACV/manifold.
For that matter it could be the drain plug in the front of the block blowing around from the wind, but that will usually hit the exhaust pipe and smell/leave white marks.
I have this problem too. exactly but i have a d16zc on my crx. still cant figure out where it is. im getting this stop leak stuff you add to the coolant, hopefully that works
m3dia_lab
08-22-2004 04:21 PM
