cooalnt foam
cooalnt foam
just had to change my lower radiator hose.
when i filled up the radiator it started faoming like the head of a beer. for about 10 minutes. then it stopped?
do i have a headgasket problem?
Re: cooalnt foam (djsire)
i doubt it.. after you drain your coolant, you have to bleed your system like you would your brakes.. air builds up into your cooling system, it'll cause it to possibly blow your water pump, overheat etc.. the foam you were seeing is a good thing.. air was just getting out of the system..
did you bleed your cooling system at all?
Re: cooalnt foam (g23_ej1)
left the car running with cap off for 10 minutes.
the car had one front wheel on the side walk(elevated)
drove for two days no more overheating
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">left the car running with cap off for 10 minutes.
drove for two days no more overheating</TD></TR></TABLE>
there you go, so you should've known that the foam was air in your system...
ive never seen it foam like that before.
i know about bubles but it literally looked like i was poauring beer in there
BlueShadow
09-02-2005 02:35 PM
