Confused on what must be removed when ditching power steering and ac
Hey i do not want ac or powersteering anymore and i'm in the middle of a swap and was just wondering what bolts and exactly from the pics can i and should i remove i'm getting mixed ideas
some say just take off the belt others say i need a new rack so let me know please
Re: Confused on what must be removed when ditching power steering and ac (bboylito)
For no power steering: remove the pump in the red box in pic 2. If you keep the PS rack, you will need to do the bypass trick (search archives) -OR- Swap in a manual rack from a 96-97CX. I have done this and prefer the increased feel.
Here is the link for the PS bypass:
https://honda-tech.com/zerothread?id=184202
For no A/C, remove the compressor below the PS pump. Then remove all the A/C related hardware scattered around the engine bay.
Both components that you want to remove are on the front, driver's side of the engne. The only belt remaining now is for the alternator.
Good luck
Modified by NXSpoon at 3:30 AM 11/29/2004
Good luck
ITR#203
04-24-2002 05:38 AM
