confused about suspension noises?
i just go new skunk 2 coilovers one peice, but when i slightly go over a bump the shock or sumthin in the area feels like its hit, not too hard tho. I kno my rackin pinnion and wheel bearings are bad. And i kno the suspension is new. what cudd it be?
Re: confused about suspension noises? (ek9tl)
Fix what you know is wrong first. Not only are you running the risk of ruining your new parts, but there is no guarantee that your new parts are the cause of your "new" problem... Not to mention the fact that a failing Steering System and/or Bearings can lead you into an accident...
Upgrade before Fix = + + $$$$$$$$
Does it make sense to get a Heart Transplant when you break your Ankle? I hope not... Use the same logic with your ride... unless you vote for the Heart Transplant... in which case you should also get a Brain Transplant, and a Wallet Augmentation.
But seriously, fix what you KNOW is wrong first. If the problem still persists, let us know... GL!!
JasonGhostz
JasonGhostz
Re: confused about suspension noises? (JasonGhostz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonGhostz »</TD></TR><TR><TD CLASS="quote">Fix what you know is wrong first. Not only are you running the risk of ruining your new parts, but there is no guarantee that your new parts are the cause of your "new" problem... Not to mention the fact that a failing Steering System and/or Bearings can lead you into an accident...
JasonGhostz</TD></TR></TABLE>
He has a point. The rack and pinion and wheel bearings are very important. Fix those soon. As for the noise. If you didnt have it before the upper control arm install then they are hitting the top of the wheel well. Its a common problem. Your car is probably pretty low.
Re: confused about suspension noises? (spoonracer84eg)
I think you should fix the job problem first. Once you fix that, then you can fix the rest.
Having a hobbie takes money. And it sounds like you need some money.
edit: And I just replied to your other post. IT SOUNDS LIKE YOU NEED TO GET A BICYCLE!!!
5thGeneration
Suspension & Brakes
10-23-2007 09:02 PM
