confirm this exhaust system
stay underground!
Location: double clutchin' in a hood near you...it's crazy right?
catco hi-flow cat and apexi N1 cannister with custom 2.5" piping all the way through on a 97 hatch with Comptech 4-2-1 headers & AEM coldair intake?
and how do i know if i need an o2 sensor bung? it's a 97 civic cx.
or ?
or ?
Electrician
Well, the head should come with the O2 sensor bung already welded in. Usually, they try to keep everything cat compliant.
As far as the custom piping, I doubt there was an O2 bung welded before the cat. Buy a bung for a couple bucks, have it welded in for a couple bucks, off you go.
Since the ECU is OBD2, there should be 2 O2 sensors.
Someone can chime in and concur of the 1996+ OBD2 Civics are 2 O2 sensored.
Re: (Dimi)
This setup probably won't work. The Hatch's all have the cat integrated into the manifold, so there is no cat underneath. Because of this, the exhaust piping is longer to meet up with the manifold. So, if you put the headers on, the cat will not fit in there. You will need to run an O2 simulator and your car will no longer be street legal, and likely throw codes w/o the simulator.
Re: (shifty35)
That'd be true about the header if he were getting an off the shelf catback. But he said he was getting a custom exhaust made.
About the o2 sensors. I'm pretty sure your car has two o2's. The header should have a bung for your primary o2. You could leave the second one hanging, but like shifty35 said, you'll throw a CEL code. An o2 sim will keep the light off, but it will stay in your computer's memory. Come inspection it will show up.
If I were you, I would have the muffler shop put on a cat and put an o2 bung after it.
what car is the header for? if its for a GSR, then it'll be missing a bung. if not, it should have a bung in it.
is the cat obd2 compliant? then it should already have a bung in it. if not, you need a bung put in right after the cat.
haha. i said bung.
haha. i said bung.
Si_Guy2000
06-16-2007 04:03 PM
