Comptech Sway/Tie Bar Combo fit on EG Chassis???
I searched and didn't really find what I was looking for.
I was wondering if the Comptech Rear Sway/Tie Bar Combo will fit the EG chassis provided that I already have Integra rear LCAs.
I noticed that Comptech only makes the kit for 94-01 Integras and not 5th gen Civics. Is this because the kit won't work on the EG chassis since they don't have the tac welded nuts on the subframe?
If anyone has the Comptech Sway/Tie Combo, please provide some insight. Thanks.
Re: Comptech Sway/Tie Bar Combo fit on EG Chassis??? (JDM Ninja)
it will work on eg anything that goes for teg suspension's can work on eg suspension's if they don't have the nuts welded there you can still put them there and you don't need to weld them, that is how the SRR kit is.
Re: Comptech Sway/Tie Bar Combo fit on EG Chassis??? (slammed_93_hatch)
I was wondering, if the Comptech Rear Sway/Tie Bar Combo fits the EG chassis, then how would you install the 30mm Hex bolt, if the rear subframe didn't have the tac-welded nuts? What would you tighten the Hex bolt to?
I just want to make sure this will fit before I go and spend $300+ on it.
apparently you didn't search very well, there's more than a few posts about this, including some by me...
yes it fits, yes you need to buy either locknuts or nuts and lockwashers for the 4 subframe attachment bolts.
here's a picture:
here's a picture:
Street Ghost
04-19-2004 04:52 PM
EM1Guru
03-07-2004 11:08 AM
