completely stumped...
pr3 b16... pulled the motor and put back in... i cant figure out why my car wont start, i have compression, fuel and spark but for some ODD reason my car will not start and run. Ive checked basically everything but anyone have any ideas one my problem??
oh and yes i have the grounds, neg battery to chassis, tranny to chassis, harness to thermo stat, and valve cover to core support.
thanks allot,
spenser
Modified by The Dirty EJ1 at 1:53 PM 4/27/2008
thanks allot,
spenser
Re: completely stumped... (The Dirty EJ1)
check your crank sensor see if it is disconnected, or if you have a bad connection throughout your harness. i had a similar problem with my civic si. did you advance or retard your timing at all when you had the engine pulled. if so that would effect starting and idling.
do you have any access to a info scanner. that tells you fuel trims or anything like that? also if you can get a set of NOID LIGHTS that will tell you if your injectors are firing. the only other thing i can think of is get a diagram of your plug wires on the distributor cap. and check to see if the wire are on the right cylinder.
MitchHamilton
15
10-25-2016 05:00 AM
