Coiled clip onto inner tie rod dust seal boot?
Having trouble getting this circular coiled clip on the end of the dust seal boot. I tried pushing the clip over and onto the boot, but its to tight. I also tried using a snap ring pliers to open it up a little and it deformed the clip.
Attached is picture of the deformed clip and the dust seal boot. This circular coiled clip is similar to a key ring. Anyone have any pointers on installing this clip? Should I have put the coiled clip on the boot before I placed the boot on the inner tie rod/rack?
Re: Coiled clip onto inner tie rod dust seal boot?
looks like it has a grove big enough for a zip tie ! nothing wrong with using a zip tie on those some of the part store kits come with them. I run those style ones on my DD jazz and track car no issues yet. those clips made me want to break something.
Thanks for replying B_Swapped93. Yes, the groove is big enough for a zip tie, but I am paranoid that the side of the locking square hub of the zip tie will eventually wear a hole in the boot. I did not know zip ties came with some part store kits. I am glad I am not the only one frustrated with the clip.
GDD Member
Almost all of the aftermarket bellows (those boots are called bellows btw) come with a zip tie instead. Most cars don't use that clip, but rather a hose clamp and the new boots are never the same size as OEM which is why a zip tie comes with it.
Those clips are really hard to put back on. On those rare occasions where I've reused them, I ended up putting the clip on the boot first, putting lube all over the inside of the boot hole, then sliding it down the shaft and working the boot over the groove.
jeffhoe
02-29-2012 09:02 PM
THE LORD OF CHAOS
11-06-2005 11:12 AM
SOHC_Brian
11-24-2004 02:01 PM
