Code 6 (ECT) water temp sensor issue... HELP!!!
What does it mean when cel code 6 keeps going on right when I turn the car on after it sitting over night. Before I turn it on I reset the ecu. It will even turn on in the on position without me having to start the car up. I replaced the switch already and it does the same thing. Any help please. Thanks....
Re: Code 6 (ECT) water temp sensor issue... HELP!!! (KILLER_EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KILLER_EK9 »</TD></TR><TR><TD CLASS="quote">What does it mean when cel code 6 keeps going on right when I turn the car on after it sitting over night. Before I turn it on I reset the ecu. It will even turn on in the on position without me having to start the car up. I replaced the switch already and it does the same thing. Any help please. Thanks....</TD></TR></TABLE>
Which "switch" - you mean the coolant temp sensor?
when it comes on does it stay on? If so make sure you have your engine harness plug in correctly, if you have a jdm swap you don't need the oil pressure sensor for vtec and you might have that plug into your coolant temp sensor by accident.
eg9d16turbo
09-07-2011 04:24 PM
310HPS2k
11-04-2007 06:33 PM
