code 4 someone help me
code 4, b16 in ek 98, checked everything please help someone changed distributer and same code on start up this sucks bad...
Solbros Owns Me
Re: code 4 someone help me (EKRACER123456)
whoa, that freaked me out, I'm in Bellingham also. What does code 4 mean? Did you reset the ECU after you swapped the distributor?
Edit- if for some reason you didn't or don't know how, just unhook the negative battery terminal for 15 seconds or so, then re check the code/fire up.
[Modified by Emerica, 6:09 PM 11/13/2002]
