Code 22
Old Aug 12, 2005 | 05:13 PM
delsolgirl's Avatar
Default Code 22
Hi. I need some help. I have 94 del sol dohc vtech. Blows code 22. It is not the oil pressure switch, or celenoid as I changed it. Not the oil pump. Switched ecu and it still does it. The check engine light comes on and it does not engage. Reset the ecu after changed switch and celenoid. Light went out. Now it is back on again. What else could it be? Also not the harness as it gives power. (I had local mechanic check all this out)
My car was stolen and new engine was put in.
Old Aug 12, 2005 | 05:15 PM
97civicdx's Avatar
Default Re: Code 22 (delsolgirl)
oil level ok?
Old Aug 12, 2005 | 05:16 PM
delsolgirl's Avatar
Yes on oil level.
Old Aug 12, 2005 | 05:34 PM
97civicdx's Avatar
Did you try to clean out the solenoid and pressure switch to make sure there isnt any gunk built up in there?
Old Aug 12, 2005 | 05:45 PM
delsolgirl's Avatar
Default Re: Code 22 (97civicdx)
I took the entire unit (celenois switch and spool) off of friend's care and put it on my car. Check engine light still came on. Thought it was ecu. Took friend's ecu and put it in my car. Check engine light still went on. Took it to mechanic. He checked oil pump and harness (both ok) He put it on his computer after he made check engine light come on. Code 22 came up which corresponds with switch) I then let him put a new switch in cause I couldn't figure it out. He reset the computer. I took the car out and pushed it til the check engine light came on again. I'm sure he checked for goop.
The only thing left is the wiring.?
Can't figure it out beyond this point.
Old Aug 12, 2005 | 06:01 PM
95DxSi-R2
Guest
Posts: n/a
i would check wiring, i'm guessing 22 is for no or low oil psi?
Old Aug 12, 2005 | 06:15 PM
delsolgirl's Avatar
I guess this would be the wiring to the solenoid unit.
Old Aug 12, 2005 | 06:31 PM
97civicdx's Avatar
Yes, Its got to be a break in the wiring. You are going to have to trace the wires from each of the sensors, looking for a possible crack in the wiring casing.
Old Aug 12, 2005 | 06:48 PM
delsolgirl's Avatar
Thanks for your insight.
I am being told to drive it for a week. I was told that the ecu can get "mixed up".
Mechanic wants me to wait a week.
What for?
Old Aug 13, 2005 | 05:12 AM
97civicdx's Avatar
Better yet, rewire each sensor and run it right to the ecu's proper plug.
Old Aug 13, 2005 | 09:50 AM
95DxSi-R2
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolgirl &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for your insight.
What for?</TD></TR></TABLE>
that sounds stupied to me
Old Aug 13, 2005 | 09:54 AM
95DxSi-R2
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx &raquo;</TD></TR><TR><TD CLASS="quote">Better yet, rewire each sensor and run it right to the ecu's proper plug.</TD></TR></TABLE>
this could be the way to go, i've had crank sensor do this ****, and i fixed it by running a hole new wire
how many wires is it? i would think it's just one?
Old Aug 13, 2005 | 10:35 AM
debo*'s Avatar
Default Re: Code 22 (95DxSi-R2)
im having this problem as well, but the check engine light comes on when im doing higher speeds on the freeway, it usually engages when i go past 90mph (very near 5th gear vtec, not sure if its related though), throws a code 22. replaced solenoid, vtec pressure switch, checked wires, etc... and still nothing.
Old Aug 13, 2005 | 10:58 AM
95DxSi-R2
Guest
Posts: n/a
Default Re: Code 22 (debo*)
sounds like pcm if youv'e checked wires and replaced everything
Old Aug 13, 2005 | 11:00 AM
95DxSi-R2
Guest
Posts: n/a
what is code 22?
Old Aug 13, 2005 | 01:34 PM
debo*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">what is code 22?</TD></TR></TABLE>
code 22 is the code the ECU gives when the check engine light comes on, when the check engine light comes on it leaves a code that you can use to diagnose what the problem is related to, and the code 22 is a oil pressure related problem.
ncsuprelude
Nov 13, 2006 08:24 PM
LUCKY CHARMS
Jun 30, 2006 07:16 AM
ekdriven
Jul 12, 2004 01:45 PM
staticrex
Jun 1, 2004 11:59 AM
PatEJ6
Feb 25, 2003 04:15 AM
