check engine light 21
Old 06-29-2006, 05:19 AM
LUCKY CHARMS's Avatar
Default check engine light 21
my mates '98 jdm itr is showing a cel light, when we crossed the pin we got code 21....vtec spool solonoid valve, we removed the 3x10mm bolts securing it,gave it a clean & replaced it(not over tightening) then reset the ecu by disconnecting the -battery, we started the car but its still showing cel.
does anyone have any words of wisdom to point us in the right direction,any help/advice would be greatly appreciated
Old 06-29-2006, 05:31 AM
Moderator
chad's Avatar
Default Re: check engine light 21 (KISS ME LUCKY CHARMS)
add oil!!!
Old 06-29-2006, 06:35 AM
Default Re: check engine light 21 (chad)
oil level seems fine but we'll change the oil to eliminate it, tanx
Old 06-29-2006, 01:02 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">add oil!!!</TD></TR></TABLE>
Code 21 is not thrown when oil pressure is low due to low oil levels.
Code 22 maybe thrown which is vtec oil pressure switch....
Code 21 is probably being thrown due to an bad connection from the vtec solenoid to the ecu. Perform a continuity test from the engine harness to the ecu. If the test comes out ok, try another ecu.
Old 06-30-2006, 07:16 AM
Default Re: check engine light 21 (mtber)
great stuff man, we'll try that! in fact now that i think of it, someone else was at his ecu last week, checking the pin for referance as he was fitting a vtec controller,
just for your info the wire had been left bare where the vtec controller was spliced into the loom, re-attached the wire, taped it up and everything was brand new, tanx for the help
Modified by KISS ME LUCKY CHARMS at 4:01 PM 7/1/2006
Immanuel
08-08-2005 02:50 PM
Kyles ej1
18
09-26-2004 04:40 PM
SlippylesKB
11-12-2003 07:21 AM
redman223
07-02-2003 03:45 PM
FusionITR
09-20-2002 12:46 PM
Quick Reply: check engine light 21
