clutch probem
clutch probem
I have a 92 civic ex, 1.5 liter. My clutch pedal is starting to stick, it takes a second to lift up, and at the same time i feel movement in the brake pedal. Any ideas?
Re: clutch probem (civiccpedx)
if that doesnt fix it check the pedal linkage for interference and look to see if the fork on the slave cylinder moves freely
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: clutch probem (johknee)
Yeah if the pedal assembly isn't loose and fluids are fine. I would check your clutch master cylinder. Take a flash light and look under your dash. If there is clutch fluid seeping out of the back of the master cylinder I would suggest replacing it. To me it doesn't sound like it is the actual clutch. Bleed the clutch system too before you go replacing ****.
