clutch master cyl.
Re: clutch master cyl. (95DxSi-R2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 »</TD></TR><TR><TD CLASS="quote"> do i need an integra, del sol, or si master cylinder? </TD></TR></TABLE>
yes
If it's not working right, check the floor under your pedals for fluid leaking down under the carpet.
yes
I am a (Trial User) Army
Integra/Civics are the same 5/8'' I looked into this.
Adjust the rod that connects your pedal to your clutch MC. Turn it away from the firewall.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 »</TD></TR><TR><TD CLASS="quote">did it</TD></TR></TABLE>Like all the ******* way? Adjust it to the MAXX!
Re: clutch master cyl. (litterbox)
open up all the connections on the hydro line from the clutch master cylinder to the slave cylinder and bleed it at each one, sounds strange i know but it worked for me when i had no clutch after a swap, i guess a bubble or some sort of blockage stopped it from working but after doing this it worked fine and hasn't had a problem since.
707EF8
07-29-2006 08:32 PM
