clicking help..
clicking help..
Lately my car has been making a clicking noise when I drive slowley.. If I romp on it the ticking goes away, I just had the oil changed.. Is it time for a valve adjustment?
Re: clicking help.. (Mr. Sparkle)
Just had the CV joints replaced.... Yea the oil is I live in FL ..... Dont have to worry about it getting to cold...
Re: clicking help.. (binkster)
why dont u tell us where its coming from? engine internally? chassis? wheel area? that might help us determine what it could be.
Re: clicking help.. (EKsnatchback)
Pretty sure the noise is comming from the engine... Its only when Im excellerating slow at slow speeds... Sounds like valves but its not as loud as my valves have been in the past
yea the noise is only happening when im moving.. if i slowly rev the engine no noise and when I coast in nutral, no noise.. just when im accelerating. CV joint?
If it was the cv joint then wouldnt it still do it when u were coastin in neutral, i mean the axle is still moving so it should still click, jmho.
Re: clicking help.. (SLOAZZ94)
is it ticking or popping...does it "pop'' while you are turning?...if it is only a ticking you might just need to clean your fuel injectors
I am sure you are going to eDiagnose a car trying to decide if it is clicking or popping. Most would consider that almost the same sound anyway.
-More info would be great.
Re: clicking help.. (-TRINiTRON-)
Click.... definetly a clicking... and I dont think its the injectors because If I leave the car out of gear and slowly increase the RPM's the engine sounds fine.. not even valve ticks.. thats why I thought it would be my CV joints.. but when im rolling out of gear there is no clicking.. only when im accelerating...
only in 1st and 2nd gear... I dont notice it after that.. it could be cause the wind.... mabey the teeth in the tranny?
Could be..have you checked or changed your transmission fluid lately?? Try changing it out with some GM syncromesh and see how it works. Check for metal in the fluid when you drain it.
