clear liquid???
clear liquid???
hey got a question for you.when i park my car i get a clear liquid puddle under my car.smells like nail polish removal check my coolant level and is the same.what could it be?thanks guys!
Re: clear liquid??? (95dxsir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 »</TD></TR><TR><TD CLASS="quote">could be gas? put it in the air and check from underneath</TD></TR></TABLE>
i did and looks like its coming out of a tube on the passenger side
Re: clear liquid??? (b18b1turbo)
How big is the puddle? Is it completely clear? It wouldn't be coolant (normally), definately not oil..
Have you checked your Power Steering fluid/brake/clutch fluid??
Re: clear liquid??? (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">How big is the puddle? Is it completely clear? It wouldn't be coolant (normally), definately not oil..
Have you checked your Power Steering fluid/brake/clutch fluid??</TD></TR></TABLE>
yeah i checked all that.the puddle is about 4 or 5 inchs wide and its completely clear.what would come out of that tube that is under the car?
There are various vent tubes to remove any moisture, etc.. from different areas of your car like headlights, battery, fog lights, etc... I can't think of much else..
not sure what it is but its def a drain tube had the same thing on my ex... may very well be the sunroof... the smell may just be some collected resin in the tubing while the clear liquid(probably water) runs through the tubes
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Do you have ABS?</TD></TR></TABLE>
no abs
no abs
Re: (yoffer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoffer »</TD></TR><TR><TD CLASS="quote">How long have you had this problem? Does it happen all the time? Or on just certain occasions?</TD></TR></TABLE>
no it just started a week ago.its getting warm outside and havent started my car up so it might just be with all the warm temp here might just be extra moister when it was sitting in my garage for the winter.i hope
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1turbo »</TD></TR><TR><TD CLASS="quote">smells like nail polish removal</TD></TR></TABLE>
Does this not scream gasoline to anyone but me?
Re: clear liquid??? (MuddinPede)
if it's gas I would hope you could tell the smell, have you checked all your fluids?
brakes ect? If they are all good I would agree and just say it's a drain from sittin all winter.
dont think it is gasoline... pretty sure it is that little drain tube in the picture b/c i had a similar problem in my 99 ex and seemed like it was comin from there mine didnt smell tho
