Cleaning my block. Help please
I have a z6 sitting at my house thats about to go into my 94 ex, after i bent a rod from almost hydro locking my old engine. My question is that its dirty as &^%* and i wanna clean it bbefore I put it in my car. I used to detail cars and i have wheel acid sitting around. I'm just not sure if it's safe to spray the block with it be cause it alunium? When i do clean it should i just stick rags in the IM and the four ports for the header?
thanks,
matt
thanks,
matt
I'v seen that before, but this stuff you spray it on and wash it off and not one speck of dirt would be left its that strong. I was just wondering if its safe because I would rather not use something that work "pretty good".
PS. I'm from jersey aswell. where in NJ you from south? PM me if you dont wanna talk on the post.
Im from northern NJ. Near the Clinton area.
I have a friend who lives in SJ, in sicklersville. Glassboro Area.
Id say try the wheel acid on an inconspicuous spot, maybe on the back. But i cant see it damaging it.
Unceasing Measure
Re: (ifIexplode)
You do realize that most of the wheels you'd be cleaning at your work are also made of Aluminum, right? Steel wheels usually have hubcaps, so you don't use acid on them.
Use your wheel acid and then, when that fails, get some engine degreaser from Advance and follow the instructions on the bottle. A power washer would help.
I did it to my old motor before i sold it. And i used a small brush with it. Probably the best thing advance sells lol.
Yeh.I come down that way about twice a month. my friends a mazda guy. Loves them for some reason.. WAWA heaven down there lol,
Take some pics when youre done.
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">You do realize that most of the wheels you'd be cleaning at your work are also made of Aluminum, right? Steel wheels usually have hubcaps, so you don't use acid on them.</TD></TR></TABLE>
However, the aluminum wheels almost always have a clearcoat on the metal finish...so when you spray the acid on them, it doesn't effect the metal since it is not touching it at all.
If you spray on a wheel that has curb rash you'll notice it start to break down the bare metal...wash it off immediately to keep it from getting worse. To spray onto an aluminum block I would do small areas at a time and constantly rinse off as you go.
LUXXXX
08-16-2006 08:16 PM
xXx Justin xXx
14
05-21-2002 10:24 AM
