Civic not accelerating while driving
Old 04-13-2009, 11:45 PM
New User
pisatower's Avatar
Default Civic not accelerating while driving
Hi guys hope you can help me, last night, i was driving my civic(1998 5 speed manual) and suddenly the gauges on the dash dropped to zero, motor still running and no power when stepping on the pedal. I coasted to the side of the road. No warning lights came on the dash. I shut the car off, restarted and everything worked again. It happened a second coming back from work tonight. The car has 216000kms . Would this be a symptom of a timing belt in need of replacement?
Old 04-14-2009, 12:18 AM
kaotikvizion's Avatar
Default Re: Civic not accelerating while driving
check n make sure your battery cables are on tight
Old 04-14-2009, 12:46 AM
R666_EK's Avatar
Check the grounds.
Old 04-14-2009, 03:02 AM
hondamark35's Avatar
no, that wouldn't be a typical timing belt related symptom.
i agree it's likely to be an electrical issue. start simple, ground straps, check battery like the other guys said... before getting in to the more tricky stuff.
Old 04-14-2009, 03:11 AM
zC-ReX's Avatar
check your speed sensor, it happened to me once. changed it out and never happended again
Old 04-14-2009, 03:18 AM
i've had that too. i threw a code when that happened though.. 17 i think. certainly a possiblity.
OP: did you have a CEL? did you see if any trouble codes were stored?
Old 04-14-2009, 06:27 AM
MonkeyMagic's Avatar
MAYBE your ignition switch has/is taking a **** on you.
MAYBE...
Old 04-15-2009, 03:31 PM
New User
pisatower's Avatar
it can't be the grounds,or the battery cables the car was still runnning. like I said the tach and speedometer dropped to zero and the pedal was dead. How easy is it to change the speed sensor and the ignition switch.
Old 04-15-2009, 05:19 PM
makin1meand's Avatar
main relay
Old 04-15-2009, 05:22 PM
SOHC_civic_si's Avatar
Originally Posted by makin1meand
main relay
You are exactly right. OP, was it fairly hot/warm outside?
mdh4
01-12-2014 06:52 AM
jlopez88
04-26-2008 03:02 AM
DaaveW
08-07-2007 03:55 PM
louisstamos
Honda Civic (2001 - 2005)
07-31-2007 06:16 PM
handydandy
08-13-2004 06:06 PM
Quick Reply: Civic not accelerating while driving
