civic engine swap/sensor question
i have a 93 civic coupe with a 95 integra LS swap and the idle is acting up jumping up and down i was wondering what sensor could be bad the sensor that is on the the top of that manifold is broken i was wondering could that make it idle funny and at around 2500 rpms it bogs a little please help
Re: civic engine swap/sensor question (grightent)
you might have a vacume leak some where check your hoses and a good trick is turn your car on and spray engine degresser around your intake manifold but make sure you know where your spraying because if you just spray it everywhere you wont know where the leak is. Dont worry it wont hurt you engine and when you got the spray it while the engine is running it will bog down and that when you know you found the leak.
homeskillet
20
01-10-2005 02:28 PM
LoudLX
11-28-2004 06:09 PM
