Civic Coilovers fittment
I have acknowledged that it is possible to fit coilovers for 92-95 civic on to 96-00 civics with the help of some spacers due to the different size LCAs. However i still wonder, would it cause any rattles or any gaps in between? would performance be effected as well? I always thought it wouldnt, but a friend said it might. So just want opinions for a larger group. thanks in advance
Re: Civic Coilovers fittment
Man i've even had rsx skunk2 rear coilovers on my civic before and it drove good.
The 96-00 model civic do have skinnier LCA's and need spacers, many use washers, to make up the difference. I know first hand i helped a buddy install my used coils on his ek hatch. If it is all torqued to spec and installed correctly there should be no issues as far as rattles or gaps. Just dont rush the process and take the time to find the right fitting spacers.
Coulovers are a "1 piece" design that the "strut" it built into the spring and whole assembly. Coulovers are also adjustable...spring/strut combos are not
hes prolly refering to the bs ebay "coilovers" that are just an adjustable spring
You will never run a strut with a full bodied one piece coilover
The only difference between the 96-00 Civic shock/spring and the 92-95 Civic/94-01 Integra is the rear shocks. The fork that mounts to the lower control arm of the shocks is wider on the EG/DC. What you need just to go Home Depot, Lowes, get some washers and you'll be fine. I'm running Koni Reds/Ground Controls on my car right now which I took from a EG hatch.
ek9vboi
11
11-07-2003 11:08 AM
