Christmas Day FUN!!
Moderator
Christmas Day FUN!!
Here is what I will be doing on Christmas Day since I have no family within 14 hours of me.
back of engine...tell me why there are extra passage ways
hole that had to be fixxed (outside view)
Inside view
Endyne Middomed, higher wristpin located pistons and eagle long rods
relocated bearing stays so that i can run ITR or GSR bearings instead of the LS, B20 and B16 bearings
hmmm....what are those??? have you seen those in a b20 lately?
the bottom
also have GSR block girdle going in....
power you ask?
well this setup with mild port and polished b16 head that was opened to 84.5 mm with toda c's, jdm itr header, itr intakemanifold, spoon itr tbody, and power fc netted me 220 and 160....
dyno sheet
i will be reworking the head and building the bottomend at .020 clearances for a "looser" engine.
enjoy...and merry christmas!!!
Inside view
the bottom
power you ask?
dyno sheet
Re: Christmas Day FUN!! (chad)
Very nice, looks like you have a fun christmas day planned. Too bad you don't have any family around you... Oh well, you can come on H-T on Christmas day, we can be your home away from home
Former Moderator
You are such a ricer bitch.
Merry Christmas bro, and make sure that block is super clean before assembly this time, eh?
Moderator
Re: Christmas Day FUN!! (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
yeah.....block with get washed with high pressure hose and degreaser....then hit the parts cleaner then high pressure water...then brake cleaner....
all 14 mm hex plugs are removed to make sure nothing is floatin in there this time....
for those that don't know....first build was nice....but snapped a rod.
at first diagnosis i thought we had oil starvation due to high G cornering (summit point t 6-8 t9 and t10) rod snapped on front straight.
after i tore the engine down, oil passage on crank posistion 5 was backed up with ALUMINUM FRAZ....about 1/2 inch thick and packed tight....it is no wonder it spun the rod with no oil(oil starvation which we knew but didn't know why) going to the rod!!!
oil pressure guage will be a requirement from no on ON ALL ENGINES THAT GO INTO MY CAR!!!!
WHY IN THE HELL DID YOU QUOTE EVERY PIC JUST TO ASK ABOUT A TURBO SET-UP?
Next time please don't quote the pics.
- B18C5-EH2
do you still have the turbo setup????
looks like fun
merry christmas
- B18C5-EH2
looks like fun
merry christmas
Re: (IntegraXSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraXSi »</TD></TR><TR><TD CLASS="quote">Nice stuff Chad .. Have fund it sounds like more fun then What I have to do .. </TD></TR></TABLE>
hows the engine and all man? havnt heard from you lately.
Re: (Hype-aaaRRRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hype-aaaRRRR »</TD></TR><TR><TD CLASS="quote">
hows the engine and all man? havnt heard from you lately.</TD></TR></TABLE>
Still havent put it in yet.. With X-mas and All I have been so busy also I am collecting parts to put on Si front brakes and sway bar and a Rear disc set up at the same time .. But the Motor is super clean
Moderator
Re: Christmas Day FUN!! (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan »</TD></TR><TR><TD CLASS="quote">What are the reasons to run looser clearences?</TD></TR></TABLE>
looser means LESS FRICTION....thus freeing up HP's....yes you can build it too loose and also too tight....
have been building mine at .015 clearances....but i'm going to try .02 this time!! woo hoo....should free up 5-10 ponies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">
is that JB weld ?
is that JB weld ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">welded up.....then cnc'd to factory specs..</TD></TR></TABLE>
pic looks funny , thats all...
Re: Christmas Day FUN!! (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">Loose, just the way I like my women
</TD></TR></TABLE>.
gross
</TD></TR></TABLE>.
gross
New User
Re: Christmas Day FUN!! (civicgirl114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgirl114 »</TD></TR><TR><TD CLASS="quote">.
gross </TD></TR></TABLE>
Tight!
Tight!
Re: (IntegraXSi)
Still havent put it in yet.. With X-mas and All I have been so busy also I am collecting parts to put on Si front brakes and sway bar and a Rear disc set up at the same time .. But the Motor is super clean </TD></TR></TABLE>
good to hear that my products are clean...as i suspected.
have been building mine at .015 clearances....but i'm going to try .02 this time!! woo hoo....should free up 5-10 ponies</TD></TR></TABLE>
sounds nice
good luck with the setup.
btw, if you do make that power, youll have more power than my motor would supercharged, and im STILL going to roll you at the expo
merry xmas chad
sounds nice
merry xmas chad
1 Post
Re: Christmas Day FUN!! (R you serious)
i'll be doing something of the same Chadwick..
-new suspension
-brake lines
-re-assembling the head
hopefully next year will be better for both of us
-new suspension
-brake lines
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious »</TD></TR><TR><TD CLASS="quote">
merry xmas chad</TD></TR></TABLE>
and the crap floweth from thou mouth!
