CHIPING TRUE OR FALSE?
New User
is it possible to get 50 hp or around that with a chip on a non-aspirated engine, my friends has a del-sol, and said u can gain 50 hp, i saw NO MORE THAN 15, and answers?
Re: CHIPING TRUE OR FALSE? (duduvr6)
on a n/a no way unless he was running a non-vtec ecu, then switched to dohc vtec with a chip...then its possible....
but all things being equal, no way you can improve the factory setup much more then 10-20hp, given that the motor is not stock....so if you have cams, head work and much more other parts...then the 20hp is possible.....
on a turbo its a different story...
Re: CHIPING TRUE OR FALSE? (Guardson3r3)
i have ...check with screamer....his setup was tuned for over few hours on a dyno to get that perfect mixture and ignition timing...he gained i belive 22whp over his stock p72 ecu....
Re: CHIPING TRUE OR FALSE? (DragIIcivic)
I've never seen a Honda chip they made more than 15. there are chips for VW's and Audi's that make over 100hp.
i just got the skunk2 race ecu for my eg and noticed a huge difference. im guessing about 20hp and a big increase in torque but have not made it to a dyno yet. also i dont know what motor you have but i have a b18c you will notice different increases with different motors.
Re: CHIPING TRUE OR FALSE? (jdmeg6)
you can gain 50hp if you have an audi or vw 1.8t but on a honda its unheard of.
New User
Re: CHIPING TRUE OR FALSE? (MiGs)
what doea a chip do anyway. my friend has a 98 gti and he got a chip from neuspeed and he said he gained like hp, but he doesn't know **** about it, so what does it do, is it just a more aggressive fuel map or something he said it took off his speed govenor too.
Re: CHIPING TRUE OR FALSE? (clean)
all chips will do is change the a/f ratios, timing, and redline (probably more but these are tehmost notable).
the chips that give you 80hp on the germans are for turbo'd cars. They change everything i mentioned but also increase the boost.
you will never find a chip that will give you that kind of gains on a honda. The way you can get 10-20 hp is, like mentioned above, throwing one on a modded engine.
But i would still have to see some graphs to believe a 20 hp gain on a chip, even on an engine with cams and bolt-ons.
Most of the time piggybacks would seem to be a better route than a chip. Depends entirely on your set-up.
evestatic224
08-08-2010 01:46 PM
scoobyghost
14
02-10-2003 05:50 AM
