check out my new engine, and 1 quest?
its a 98 d16y8 motor, to replace my d15b7....i just wanted to show you a pic of my new engine i got about three days ago from a guy here on honda tech...i'm planning on turbo, i will post up my steps when i start
Re: (pennies_hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie »</TD></TR><TR><TD CLASS="quote">the black thing is the knock sensor</TD></TR></TABLE>
Looks like the PCV to me.
No its not !!! Its a breather where the PCV valve is located. See the blue thing on the hose that goes into the black box thats the PCV valve .
Re: (G2AT8K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2AT8K »</TD></TR><TR><TD CLASS="quote">
No its not !!! Its a breather where the PCV valve is located. See the blue thing on the hose that goes into the black box thats the PCV valve . </TD></TR></TABLE>
no need to HATE..
my mistake
no need to HATE..
my mistake
Re: (Eibach95Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eibach95Civic »</TD></TR><TR><TD CLASS="quote">where is the knock sensor located at then?</TD></TR></TABLE>
I dont think those motors came with knock senors.....thats a oil pressure sensor if im not mistaken (above the oil filter)
Re: (eg cookiemonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg cookiemonster »</TD></TR><TR><TD CLASS="quote">
I dont think those motors came with knock senors.....thats a oil pressure sensor if im not mistaken (above the oil filter)</TD></TR></TABLE>
yes i believe they do have a knock sensor...
my mistake before, im just use to seeing them on b-series having a black housing...whoops
no need to HATE..
my mistake</TD></TR></TABLE>
no need to HATE..
Re: (13HYBRID20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13HYBRID20 »</TD></TR><TR><TD CLASS="quote">pcv: positive crank case ventilation. And yes thats what it is. Knock sensor retards your timing if it sences knock.</TD></TR></TABLE>
I still dont understand what pcv does.
Re: (Jackson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jackson »</TD></TR><TR><TD CLASS="quote">
Looks like the PCV to me.</TD></TR></TABLE>
how much did u get it for?
Solbros Owns Me
Re: (bearboy80)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bearboy80 »</TD></TR><TR><TD CLASS="quote">
I still dont understand what pcv does. </TD></TR></TABLE>
The PCV valve is just a one way check valve that allows blowby gasses in the crank case to be "re-released" into the intake manifold, but will not allow intake air to enter the crank case.
Serves same purpose as EGR valve: Exhaust Gas Recirculation valve....emission puposes
The big box is the collector, and that is NOT the PCV valve into it...that is just a connector. The PCV valve is visible from above the intake manifold, which presses into the that hose goes up.
Re: (JasonBlackEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonBlackEJ1 »</TD></TR><TR><TD CLASS="quote">
how much did u get it for?</TD></TR></TABLE>i got it for $500...i got everything included.
motor, tranny, ecu, wiring harness (i have no clue on how to hook it up?), axles, engine mounts, and engine comes with 85,xxx miles
Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
]b]Serves same purpose as EGR valve: Exhaust Gas Recirculation valve....emission puposes[/b]
well it achieves the same goal (lower emmissions) but it doesn't serve the same purpose...
pcv vents oily fumed air from your crankcase to your intake...
egr recirculates overly rich exhaust gases back to the intake to burn again...
Re: check out my new engine, and 1 quest? (careawholelot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by careawholelot »</TD></TR><TR><TD CLASS="quote">nice motor put it in the car already</TD></TR></TABLE>no not yet, im going to buy new clutch(any suggestions?), timing belt, and get a new water pump
Boostfed
09-30-2005 10:59 AM
