Check Engine Problem Code 92
Old Jun 20, 2005 | 04:28 PM
jsou's Avatar
Default Check Engine Problem Code 92
My check engine light came on while driving yesterday. The car drove fine, so I did a driveway check and came up with 92 (Insufficient Purge Flow or Defective Emissions System). I have a LS engine in a 96 civic. To have it pass the ref inspection I swapped out the 99 LS EVAP canister with a 96 LS. No check engine light then and I passed ref and smog. I think it has to do with a bad canister now. I'm wondering if I should just switch back to the 99 EVAP cansiter since I passed the ref inspection. Also, is it ok to drive even though the EVAP canister is bad? I'm still trying to learn about these things. Thanks.
Old Jun 27, 2005 | 05:26 PM
jsou's Avatar
Default Re: Check Engine Problem Code 92 (jsou)
any help?
Old Jul 22, 2005 | 06:10 PM
Swanny007's Avatar
I dunno. Try http://www.obd-codes.com
Old Jul 24, 2005 | 10:23 PM
jsou's Avatar
Default Re: (Swanny007)
Update
I had the canister switched back to its original canister which is the the one that came with the engine. I had a mechanic back home do it and he figured it was the 96 canister that had a problem. Anyways today driving my check engine light came back on and I pulled out the same code. Not sure what to do. Any suggestions? Also if anyone knows of a good mechanic down in Thousand Oaks, Camrillo, Calabasas, Van Nuys anywhere around here I'd appreciate it, i'm down here for the summer and don't know of anyone down here.
kpatiag
Oct 5, 2008 12:03 AM
racer_X_123
Feb 7, 2006 11:21 AM
racer_X_123
Nov 15, 2005 03:56 PM
SexyAzNMami
14
Mar 28, 2005 04:29 PM
99SedanEX
Feb 7, 2005 12:59 PM
