Check engine code...????
Old Feb 5, 2005 | 12:03 PM
ThatsMyEG's Avatar
Default Check engine code...????
does anybody have a site of a list of check engine codes or know what code 13 is??? cars not starting sounds like its starving for gas...
edit:
13 BARO - atmospheric pressure sensor , anybody know where this is located or know if theres another name for it doesnt sound familar.
Old Feb 5, 2005 | 12:04 PM
Luserkid's Avatar
Default Re: Check engine code...???? (ThatsMyEG)
hmm.... do i know a site that could tell me CEL codes. Well does anyone know one
Edit: Yes i do, its called H-T in the EG forum the FIRST thread there.
https://honda-tech.com/zerothread?id=682412
Old Feb 5, 2005 | 12:05 PM
jlacoy82's Avatar
71.192.16.183
Its the first thread in this forum.
Old Feb 5, 2005 | 12:17 PM
Luserkid's Avatar
Default Re: (jlacoy82)
Helms says your ecu is poopoo. Reset the ecu and if that doesnt work then replace with another ecu, then the light should be gone. Give me a min and ill post the pic.
Old Feb 5, 2005 | 12:20 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (Luserkid)
What page Luserkid? I want to see.
Old Feb 5, 2005 | 12:24 PM
Luserkid's Avatar
I so need to clean out my we-todd account so i could post pics faster.
Old Feb 5, 2005 | 12:26 PM
ThatsMyEG's Avatar
yeah me too this sucks i have a haynes manual but i cant find it in here im a idiot i guess.....
i just need to unplug my ecu to reset it?
Old Feb 5, 2005 | 12:29 PM
Zekers's Avatar
Default Re: (ThatsMyEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsMyEG &raquo;</TD></TR><TR><TD CLASS="quote">yeah me too this sucks i have a haynes manual but i cant find it in here im a idiot i guess</TD></TR></TABLE>
No your not an idiot, haynes manual just sucks. I'm saving up to get a helms manual.
Good luck getting your car running.
Luserkid's Avatar
i just need to unplug my ecu to reset it?</TD></TR></TABLE>
Unplug your batt for a min.
Mr.OB*GYN_Rhett's Avatar
Good luck Matt
Old Feb 5, 2005 | 12:31 PM
jlacoy82's Avatar
71.192.16.183
Basically, or just disconnect your negative battery terminal for a short period.
Then once you get it hooked back up, jump the service connector and check for codes again. If the light stays lit solid, it means its been cleared and there are no stored codes. If it comes back as code 13, looks like you'll be buying a new ecu.
Old Feb 5, 2005 | 12:40 PM
ThatsMyEG's Avatar
ok i just did this the light turned off but the car still wont start still sounds like its starving for gas this is what i checked so far
fuel pump
regulator
plugs / wires
vacuum hoses
any ideas
thanks for the quick responses and advise also...
Old Feb 5, 2005 | 12:46 PM
Luserkid's Avatar
So your getting fuel and spark right? Hows your timing?
Old Feb 5, 2005 | 01:46 PM
ThatsMyEG's Avatar
right before this all happened it was running like crap it kept bogging up and down so i dont really think its my timing, but it easily could be ill have to check it later cause im at my apartment and i have no tools..
Old Feb 5, 2005 | 01:54 PM
jlacoy82's Avatar
71.192.16.183
It could have jumped a tooth/several teeth on the timing belt. Do you at least have enough tools to remove the timing belt cover and inspect the condition of the timing belt?
rhdins
Jun 11, 2008 10:13 AM
wantjoule
Honda Civic (2001 - 2005)
Jun 11, 2007 05:09 PM
Lscivic1999
Jan 24, 2007 12:22 PM
Type R CivIc
Apr 6, 2005 11:57 PM
GSRdriver
Dec 25, 2001 12:48 AM
