chattering noise 96 civic
so i just traded my eg for a 96 civic coupe dx. The car has a chattering noise when im accelerating. When the car is out of gear, there is no noise. When its in gear there is also no noise but when i accelerate the noise would start. Sometimes there is no noise until higher RPM or when i switch gears. can it be the clutch? transmission? doesnt sound like the engine, but could be a possibility. Any help would be appreciated! Thanks!
Re: chattering noise 96 civic
Your valves are probably out of adjustment. Usually they will chatter alot when under load (i.e in gear), Mine does this too, especially when I go up hills. Its easily fixable, but I haven't had the time.
here's a tutorial https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/tech-article-valve-lash-adjustment-1305086/
But it sounds like it's coming from thetranny. I'll take that valve adjustment into consideration tho. Anyone else that mite of had similar possibilities?
2000, 95, 96, accelerate, accelerating, chatter, chattering, civic, clattering, honda, load, noise, rear, rpm, valve
